fdorn
Everything posted by fdorn
  1. sensational - thanks for posting JP
  2. Thank a million for posting this -
  3. I have an 01 with 70k miles. I have noticed this same issue between 1700-2000 rpms. No faults. It seems to happen more often when the car is cold. It doesn't happen all the time. Plugs, coils, new MAF did not fix my problem. willmac996 - can you please provide more detail on what 'loose intercooler pipework' means when you have it.
  4. I would be hopelessly lost if I hadn't run into you on these and other boards!!!!!! Thanks Frank. Hope this is useful....
  5. I have the clutch package from Kevin (Ultimate)...sachs stage 2 GT3RS with LWFW.... +1, I would call Kevin. I run his performance clutch (dual mass) and could not be happier with it or with his help.
  6. here is the DIY I used http://download2.firsttraders.com/996tt/swremoval.pdf
  7. Thanks to Mark P. at MVP for a great day. Thanks for the ride in the Radical. Car is just hooked up since Kevin@UMW spent a bunch of my dough (suspension upgrade suggestions, UMW performance clutch, and UMW flash). Couple of events ago I blew a coolant hose and felt so stupid because Kevin told me to swap the hoses out to the 997 hose and superceeded 996 hose as a precaution. Neither of these were the culprit, but my shop told me they were going to be. I would not ignore this suggestion Kevin has made. One trip across a rumble strip could be all it takes. Couple of pics - Anil took these...he shots some of the best pictures I have ever seen. I took these - obviously a different quality of picture - I tend to go with the blurred, crappy look. The guy who ran the event (Mark P.) took me for a spin in his Radical. 200hp 1000cc Kawasaki engine from a Hayabusa. Curb weight - 1000 lbs. Godzilla One of the nicest looking M3's I have ever seen Roush Mustang Some not so good pics of yours truely. I bought some package at the track and will post those when I get them.
  8. Sorry to hear of your misfortunes - but, in my mind, its much more of a nuisance than anything else. I will do whatever it takes to help you 'survive this bad time'. Speaking for myself - you have helped me so much with sooo many issues that I am not sure who I would turn to if you vanished from Reen or 6. If you go the F40 route, I will be forced to folllow which will result in plunder the kids college funds and forceing them to eat rice 3 times a day. Life is too short not to enjoy the car you drive. For me - the enjoyment far outways the expenses. :drive:
  9. I have an 01 without x50 and the vin decoder says the 450hp for me. I remember this being discussed before, but I can't find the thread right now.
  10. Thanks everyone. I plan on getting it fixed in the next day or so. Just wanted to know the risks. Appreciate it.
  11. My front wheel housing liner came loose(somehow) on the expressway yesterday and I absolutely ripped it to shreds. I had to remove it completely so I could drive. Just want to make sure it is OK to drive the car until I can get it replaced. Thanks
  12. Take a look at this also http://www.renntech.org/forums/index.php?s...telephone+power There is key on power 12v for a phone module in the center consel.
  13. NICE!!!!!!!
  14. My was from a worn old coolant resovior. No real sign of it until the end. http://www.renntech.org/forums/index.php?showtopic=28238
  15. Have also sent two emails and would like to know myself if anyone knows.
  16. FWIW - I have it installed also and love it. Great compromise between a short shifter and 996 shifter. Highly recommend it. Its very inexpensive. I wish I did it the day I bought the car. Drive a 997 if you want to see what it is going to feel like.
  17. Danny, Is there anyway it could be a misfire. I had something similar (the whole back end shook like h$ll under full acceleration). The 1st time it happaned I got ABS/PSM and CEL light. After I turned the car off and back on the lights were gone, but still stuttered under full acceleration, most of the time with no CEL or ABS/PSM lights. Changed my plugs and MAF the car rips like normal. Did you read this by chance http://www.renntech.org/forums/index.php?showtopic=24413
  18. Was coming from the coolant reservior - old and worn out. Being replaced under extended warranty...Thanks to everyone for input and help.
  19. Thanks for the info and diagram. Tremendous help all of you. I will let you know what it turns out to be. I am running out of time before the next track day and forced to drop it of at the dealer in the morning. Hopfully covered by warranty, but needs to be fixed regardless. Would hate to get stranded at the track or worse not be able to run - or put someone else in danger cause of a fluid spill on the track. Anyway, great forum full of great people with tons of knowledge....props to you all... peace.
  20. Thanks Loren and wvicary
  21. Any guess what this leak is from: I believe that pipe is the left intake pipe that is coming from the drivers side oil collection container. The fluid does not look or feel like oil. I am headed to the track in a few day and wondering if I should take care of this first.
  22. That is the part that scares me. I wouldn't mess with it. For a little more money you can get it done right (ECU flash) and not put your $28,000 engine at unknown risk.
