longhorn911
Everything posted by longhorn911
  1. Thanks for the info - I ended up having my dealership replace the unit.
  2. Yes - those are the ones I tried. The 4.8mm terminals are too wide and the 2.8mm terminals are too small. They don't look like the Porsche ones either. I appreciate your response - youu wouldn't think this would be so hard!
  3. I have a Spec Boxster that I'm wiring some extra items in (cool suit, blower, camera, etc) and want to tap into the fuse panel from the back rather than the front as it has been relocated in the footwell and I don't want any dangling fuse jumper wires that could get accidently kicked out. I have several empty slots in the fuse panel that I want to use. What I'm looking for is some fuse terminal inserts that I can insert into the empty slots in the fuse block from the back (simlar to those pictured below). These are the terminals that each prong of the fuse slides into from the front. I cannot find a Porsche part number or any reference anywhere to these terminals. My dealer says they are only available in very large quantities. I could buy a salvage fuse block, but I only need two terminals. I've even tried a Volkwagen part that I was told was simlar, but it did not fit correctly. Does anyone have any ideas where I get a couple of these for my 986 Boxster fuse panel? ...
  4. Thanks for the link, logray. I'll definitely look at that part. Loren - do you know if there are any major challenges to know about ahead of time if I try to replace this part myself. It appears that it is just a lot of unbolting and re-bolting. I'll use fresh screws and nuts and get an alignment afterward. Also - do you know where I could find the appropriate torque values for the nuts?
  5. Loren, If I look at used parts, would either 986.331.052.06 or 986.331.052.08 work? Do you know what the difference are? What about the part number that is stamped on my part (986 331 152 7R) - is that a real part number? Thanks Kevin
  6. I have a 99 Boxster with a cracked suspension piece that is termed either a “Right Rear Wheel Carrier Inner Support F” or a “Side Section F” piece on the online parts sites. It is shown as item #3 in the diagram below. Two questions: The part on my car is physically stamped with two numbers: 986 331 152 7R MBF 34102 I cannot find that part number anywhere – all the online catalogs insist the part is either: 986 331 052 06 – about $500 (ouch) 986 331 052 08 – about $700 (double ouch) So I can’t tell which if the two above I need (06 or 08) and also can’t figure out why the part number stamped on my actual part does not show up anywhere? 2. Does anyone know how difficult this part is to actually remove and replace? It is bolted directly to the tub and I don’t know if it will be just a simple matter of unbolting or if the attaching stud (part #11) will need to be replaced, etc. Is this something I want to attempt myself or should I take it to the shop to do? Obviously after everything is replaced, I’d get an alignment. Thanks in advance, Kevin
  7. Thanks guys - exactly the info I needed. One question remains: do you think I will need to make any adjustments to the cables when I reinstall? The throttle works great right now and I'd hate to have to readjust without knowing what I'm doing... Thanks again everyone. Todd - I sent you a PM...
  8. I've searched for a while and couldn't find the answers to my questions, so I apologize if I missed them... I've got a non-e-gas accelerator pedal with a hinge that is ripping free of the base unit. The hinge is broken and the base unit screws are also stripped so it looks like I need a new base unit and hinge at a mimum, so I may have to just buy and entirely new aseembly. My questions: 1. I've seen several DIY's (with pictures even) for the e-gas version of the unit, but not the wired-throttle version. Is the throttle cable difficult to remove and reattach to the unit? 2. When I replace the assembly, will I have to re-adjust the cruise control or throttle cables or do they just pop back in with no adjustment required? 3. Loren - can you tell me which part number I need? I've seen many part numbers online for mutliple versions of the assembly and it looks like they may have been revised over time. I have a 99 986 with cruise control and 5-speed. Thanks in advance!
  9. I accidently filled up with regular unleaded (87 octane) rather than the recommeded super unleaded (91 octane). I know the computer will adjust the timing so that the engine will run on lower octane (albeit with less HP), but will the prolonged period of running a full tank of 87 hurt the engine in any way? The 996 owner's manual says that the car will operate normally on at least 95 RON (I think 87 octane is about 91 RON?), so that doesn't sound good. Should I siphon out the gas?
  10. A couple of weeks ago I was tracking my 2003 996 at a DE at MSR outside of Ft. Worth. It was a very hot day (104-106) and during one of the afternoon sessions as I was driving through a high speed corner, my check engine light came on (solid). I drove back to the paddock and one of the other drivers had an ODB reader and it reported three codes: P0300, P0301, P0306 I looked them up on the net and found that they were random misfires, cylinders 1 and 6. We reset the codes, but I wasn't going to risk taking the car back to the track. I drove it to a local dealership the next morning (the CEL light never came back on). The service manager told me that if the light wasn't blinking and didn't come back on after being reset, then the problem was probably just a random event, possibly related to the high heat and track conditions (maybe a bit of vapor lock) and not to worry about it unless the CEL light came on again. Since then, I've driven the car another 200 miles with no CEL. Any ideas what could have caused this? I do have an EVO cold air intake system and I noticed the air filter is looking pretty dirty - could a dirty air filter cause this? Any thoughts would be appreciated - not sure if I have a problem or not...? I have another track event coming up in September and want to make sure everything is in good shape before I go. Thanks in advance! longhorn911
  11. Thanks again Loren. I'm going to contact Evolution Motorsports to ask about mine since their web site claims their current shipping model is designed to keep intake air cool. But you've got me concerned - what are the ramifications with drawing in hot air?
  12. Thanks, Loren. Is it just a 3rd party air filter or is it more than that? It appears that a large part of the normal air intake housing has been removed and replaced with the smaller air filter. Also - what is CEL and what kind of sound difference does the unit make? It's interesting that you found a flat spot between 4-5K, because my car pulls very hard through that range. Sorry for all the simple questions, but I'm a Pcar newbie...
  13. I bought my 996 used and the air filter looks very different from factory. Can anyone tell me what this is? Is this a good thing? Thanks, Longhorn911
  14. Excellent - thanks. You guys are great... I appreciate the help.
  15. Thanks for the info, dj996. I realized I forgot to ask about passing wires from the trunk into the cabin as well. I have to mount the laser units inside the front grill openings. Is it an easy matter to route those wires into the cabin? Thanks, longhorn911
  16. I'm going to install a laser diffuser system that requires a couple of wires to be passed from the engine compartment into the cabin for a dashboard-mounted switch unit. How is the best way to pass the wires into the cabin? Is there a sealed access hole through the firewall? Thanks in advance...
  17. A close-up showing the gap at just under 1/8 inch...
  18. I just got my car back with a new set of side skirts intalled. It looks great, but there is a small gap between the edge of the skirts and the side of the car. It appears to simply be the thickness of the double-sided tape used to affix the top portion of the skirts to the car, but I'm not sure. If any of you have these skirts installed, can you see how large your gap is and let me know (also let me know if they were installed at the factory or if you had them installed after market)... I've posted a couple of pictures of the gap below... Thanks, Longhorn911
  19. Thanks as always, guys. This is a great forum! Going back to stock is an option, but I'm still considering having the switch added. Do you think my concerns about creaks and rattles after having the interior removed and reinstalled is valid or can it all be done and remain squeak and rattle free? Thanks
  20. I have a beautiful new 996 that came with PSE installed without the switch or the electronics (in other words it is on all of the time). I absolutely love the sound of the PSE, but unfortunately due to a medical condition I have called "hyperacusis" (which is an increased sensitivity to loud noises), the PSE is often too loud for me and I have to wear earplugs when driving. As a result, I think I will eventually have to have the electronics and switch installed so I can turn PSE on and off. However, that will require a lot of labor and expense and I'm worried about creaks and rattles due to much of the interior having to be disassembled to install the switch. While I'm deciding, I'm curious if there is a way to just manually disable the PSE directly on the exhast itself by closing the valve so that it is off all of the time? Given that PSE was installed without any electronics, is that even possible? Thanks, -- Longhorn911
  21. Wow, Thanks for the very informative answer, Loren. If you wouldn't mind, I'd love to get a copy of the install instructions for both. I'll PM you with my email address. So I assume there is really no difference between the 99-04 cars where the skirts mount and that any of these 996 narrow body skirts (cup and cup II) will fit? Also - any idea what the difference between the G2X part numbers you gave above and the 000-044-802-05 part number listed in the Techquipment catalog? Finally, am I to understand that the adhesive kit (000-044-000-37) includes the retaining strip, templates, screws, u-clips, adhesive film, etc... that you list above? Thank you very much for all the terrific info, Longhorn911
  22. I'm trying to determine the correct part number for the older "Cup" style side skirts to order for my 2003 996 Coupe. These are the older, more rounded skirts as compared with the newer GT3 or "Cup II" style skirts which have the razor-sharp edge. My dealer tells me that the part numbers for the rounded "Cup" skirts are 99655998001g2x and 99655998101g2x, however he says those are only meant for cars up to MY01 and that they don't come with any mounting hardware. The Tequipment catalog lists another number of 000-044-802-05 for what appear to be the rounded skirts for MY02 and newer cars, but the dealer is unable to find much info about them in his computer (he's going to have to check with Porsche directly on this). For those of you who have MY02/03/04 cars who have the "Cup" rounded skirts, can you tell me what part numbers you ordered? Was any additional mounting hardware required? Thanks in advance, Longhorn911
