87#184saleen
    2004 porsche cayenne s
87#184saleen's Achievements
  1. i havent checked if theres a code i need to take to a place were they have a Durametric scanner do they have a part number or i have to buy the fan also
  2. yes wvicary they do only the small one when the ac is on the temp gos over 200f and i dont hear any fan on
  3. Yeah checked for fuses but cant find none related to the fans I don't know in what temp does the fan turn on
  4. i have a 2004 cayenne s im having problems with my fan it doesnt turn on it runs cool like 180 on the freeway but when i start sitting on traffic it starts to heat up and the main fan doesnt turn on i just chage my water pump thermostat and water temp sensor i wonder what it is fuse relay or what if anyone could help o by the way i upgraded the cooling pipes a while back
  5. cayenne69 if you could send me the pdf for the steps it will be a good help also what area did you cut the carpet lmk thanks oh loren i tried to donate a couple of bucks but cant figure out the steps lmk thanks for this great site thank you guys.
  6. any one have the steps how to replace the fuel pump do i have to remove the carpet ?
  7. Thanks for the help im just going to replace both of them also any good sites with the pumps.
  8. theres no engine code what i think happend i left my truck parked for a week on a empty tank i think its my driver side fuel pump it happend before but then it went away
  9. so yesterday i started my 2004 cayenne s and it started to miss fire were the rpm was really going up and down so i changed the battery and it was doing it again so i went under the driverside and bang the tank with my hand and i heard the fuel pump went on suddently everthing was working correctly dont know what is it ...it might be my fuel pump getting stuck or what..lmk guys thanks.
  10. Here is an update...Brought to the dealer, they've done some tests and found no error and the problems recurs intermittently... reset the system press 158 @ the same time it should reset it :D
  11. it might be the one by the canister i have a evap system fault code p0442 i think it might be my purge vale that stays closed or opend
  12. i want to know we re is the purge valve does some one have any pics lmk thanks
  13. i found the problem it was the fuse guys thanks
