jijioz
Everything posted by jijioz
  1. thanks loren do you know any place on the net where i can buy this relay from coz i live in bahrain and the dealer here is very expensive :)
  2. i want to change my convertible relay my car is a boxster S 2000 model i found this item on pelican parts, can anyone advice me if it will fit? Convertible Top Relay, Boxster (1997-99) part no: 986-618-111-02-M100 i am just worried about the year thanks
  3. i cant find the trip button i attached a picture of my PCM maybe it will help
  4. i have the same problem, nthing major but a bit annoyinh when i put the ac on hope someone knows a solution or what is causing this.
  5. is there a way to check the software version?
  6. hi my car is a boxster s 2000 model and on my PCm i don't have a trip button how can i check the version? thanks
  7. There is!!!!! TRy this link http://www.renntech.org/forums/index.php?s...mp;#entry108664 It worked for me :renntech: IT WORKED i really thank u guys u rock i found out after i followed the instructions that the fuse in the back of the unit is broken as well as a fuse in row E which refered to as info fuse i replaced both and unit working. i jst need to find the code and i am all set. thanks
  8. thanks guys for the replies i checked the fuse in the box and it seems ok any idea how to check the one at the back of the unit?
  9. hi guys my car is a boxster S 2000 model the soft top light is always on and the top wont go down. so after reading 100s of topics i checked all the following: 1- my handbrake sensor is working fine and i get the light in dashboard 2- when i unlock the top the windows go down halfway immediatly 3- i removed the double relay and tap it few times and then put it back again (did this step few times) still does not work, but it makes a small clicking noise with few seconds interval when i press the button. can anybody guide me how to manually open the top? thanks
  10. hi i just bought a 2000 model porsche boxster S, 5 speed automatic gear - tiptronic the radio system is Porsche PCM and under the radio it is written Porshe navigation the problem is that the whole system is dead and refuses to turn on, there is no error msg what can i check? to try to figure out the problem thanks
