95rover
Everything posted by 95rover
  1. I have no problem paying the dealer to do the update, if it is a legit deal. Just another $80 on top of the near 400, is starting to push into buying a Garmin portable Nav unit!
  2. This comes from the local Porsche dealer here in Northern Illinois (Chicago Area). They told my wife that they need to do a system update that will cost $80= 30 minutes before we can use the updated (assume 2008 version)Navteq discs? Huh? Is this a PCM firmware upgrade? Paying $80 to have a tech insert a CD seems odd...I probably am not getting the full version of the story here, but just curious- Thanks!
  3. Perfect....Thank You...! That was a fast response too.
  4. Other then taking off a wheel and measuring the rotor to see, is there a way to tell if the brakes are 330mm or 350mm? I ask as I need to replace the pads of course.
  5. You could join another forum that I joined a little bit ago- www.bobistheoilguy.com There are users that post there UOA's from a wide range of vehicles. The site helped steer me to better air, oil filter and suggestions for oil change intervals.
