e7lew
Everything posted by e7lew
  1. this issue only occur in :- Early in the morning when I turning on the car.- After stopping the car for a long time (5 hours and more) and Turing it on.These situation are noticed only after changing the oil.So it is possible to use my car with this problem? Is there any risks if I continuo using my car?Thank you
  2. Good Day, C2 1998 190k miles It's been noticed the last few days a white smoke (kinda blue) coming out from the right ((exhaust)) only! that does only occurs early morning around 1 min when turning on the car or when it is left parked for a long time (five hours or more). To take in consideration the valve seals Has been changed and head gaskets In less than a year. I think ( maybe ) this only occur when the type of oil changed To titan supersyn 5w40 I checked the water level and oil level they are normal all the times. Also there is no water showing in the oil. Your help is appreciated Best Regards,
  3. hi 996 c2 1998 I have no problem with fans low speed/high speed Working well Only want to operate high speed at 206f is this correct ? Other question Is it possible to run a low speed at startup Is there a way?
  4. The car was sold before i solve the problem
  5. ABS failure thanks BJoe996
  6. can you help me to find it in ebay thanks
  7. i have carrera 98 What is the part number where i can buy it is it different from Models 99 00 01 02 ? Thanks
  8. I noticed today that when the car is not running, the pedal is absolutely fine. When the car is at idle, the pedal is much, much softer, and almost sinks to the floor when pressed, a very soft feeling. Something important to say when the car is driven I feel it is very heavy and increase in engine temperature Is this because of brake servo ?
  9. Why do you think the Toyota unit would be better? Cause they never break or set a foot wrong?? I'm sure the compressor Porsche uses is a Japanese unit already. I did not say I think so and I have no experience in such matters Specialist who told me and I wanted to hear your comments
  10. Compressor must be replaced I asked one of the garages specialized in air-conditioning they said we could install Toyota Compressor and will be stronger and better Is this possible?
  11. The specialist told me he changed the whole i trust him I installed Used one in good condition not new
  12. Was a long day with specialists Everyone agreed that the oil pump good and proves this through the oil gauge when driving the car I was at The official agent for Porsche told me under 1 normal When the vehicle model 99 is normal to have a slight weakness Oil pressure gauge now 7 to 6 bar not less When the temperature is about 90c i Will try 5w50 am sure that the problem is not from oil pump there is another problem somewhere
  13. i changed oil pressure sender and oil pressure relief spring with piston nothing changed any advice ?
  14. I did not see oil pressure warning ligh never so far Yesterday, I left the car about 30 minutes temperature was 92c , 0.7 bar not less tested while idling it reads at 5000 rpm 3.9 bar Thanks for the tips i'll let you know soon
  15. does this mean oil pump is ok ?
  16. it reads on cold startup around 4.8 4.9 it read at 3000 rpm in 5th gear 2.9 i use 0w40 ( my fisrt time ) oil level is ok When at idle long time pressure drop under 1.0
  17. I Use Mobil 1, oil filter new oil gauge is ok oil pressure rise more when the engine temperature down to 80 or a little more and less than 1 when the engine temperature increased as shown in the picture above What should I do now Do I have to worry about this I asked some Mechanical Engineers here and they said that it's normal, especially at high engine temperature and oil
  18. I have a 1999 Porsche Carrera the oil pressure when the car is very hot drop in less than 1 Is it normal? Note: I live in a very hot country
  19. thanks it was fuse issue
  20. how can i check the fuse and where ?
  21. I just bought a 2000 boxster Horn not working but i can hear the horn sound when i use the remote key to open the doors any idea how to fix ?
