mitymikec
Everything posted by mitymikec
  1. Where can u get those rotors and pads? how much r they?
  2. That front end is sick!!!!!! wow...
  3. "!" and service now - afaik means the service interval, so after you change the oil, filters and what is required for your mileage, you need to reset this with a piwis, pst2 or durametric. and besides that it does it also wrote "headlamp height adjustment" in the fault cluster menu ? if so, I believe that only piwis will help, cause the durametric doesnt has that. maybe it needs to be reset or calibrated. havent hear of something like this before, even for the guys who droped their cars lower than yours with the KW V3. maybe someone who has allready done this can help. again, what year and engine do you have. My cayenne is a 2004 with the 4.5L V8 ..S model does it also wrote "headlamp height adjustment" in the fault cluster menu ? yes, it says it as soon as i start up the truck. On the cluster..is there a sensor that can be fault that runs the adjusters? I know the lights do go up and down cause when i start the truck the lights come up.
  4. "!" and service now - afaik means the service interval, so after you change the oil, filters and what is required for your mileage, you need to reset this with a piwis, pst2 or durametric. and besides that it does it also wrote "headlamp height adjustment" in the fault cluster menu ? if so, I believe that only piwis will help, cause the durametric doesnt has that. maybe it needs to be reset or calibrated. havent hear of something like this before, even for the guys who droped their cars lower than yours with the KW V3. maybe someone who has allready done this can help. again, what year and engine do you have. My cayenne is a 2004 with the 4.5L V8 ..S model
  5. thanks, my cayenne has been lowered with springs not a lowering module. it has xenon lights in it too. ! is lit and service now is on the cluster as well as check headlamp adjustment height. There seems to be a allen key tool that can be used to adjust the heights, i was thinking of giving it a few turns and see if they go any higher. I went to the warning indicator menu on the cluster and it does not explain what the code or fault was besided headlamp heights adjustment.
  6. quite a few view but no responces..what gives?
  7. hey guys just wondering if anyone can help me with this..My 04 cayenne s has been lower a few inches..Not sure if this would set the headlamp adjustment warning on my cluster. The headlamps do go up and down. Does anyone think that adjusting them manually would work and fix the problem? I also have a service now light..is there a cheap scanner I can buy to check codes?
  8. This is my Cayenne S..It's sitting on 22 inch wheels.
  9. Just wondering if anyone ever uses 87 octane fuel in their cayenne? I notice the truck is sluggish when i use the 87 octane but i dont drive it hard when i have low octane fuel in it. Anyone notice a difference in fuel mileage when using low octane fuel?
  10. Has anyone put a remote starter in their Cayenne? any problems with it? Its getting cold up here and thought it would be a good idea...thanks...
  11. Can someone give me the Bosch part number for the wipers on a 2004 Cayenne s? front ones of coarse..
  12. Can someone post the filling procedure for Cayenne S with tiptronic tranny? thanks...i can't find it anywhere.
  13. I had the Cayenne checked out at my buddies tranny shop..They are almost certain it is the shaft seal for the torque converter. It also looks like a simple job for the re and re....will let u guys know how it fairs out in the next few weeks after i get it done..
  14. Has anyone brought their bone stock cayenne S 340 hp to the track?
  15. Well last night temps dipped into sub zero's here and the heat takes a long while to get hot..how is the heat in everyonelse's cayenne? my gauge is in a good range but heat is not as hot as a i liked..can i bleed the system by simply removing the coolant cap and letting it over flow?
  16. I too had the coolant pipes replaced and still smell coolant once in a while. i can't find a leak. i was told there was coolant under the intake that needed to evaporate? beat's me....my gauge does go upto 3/4 in warm weather but since things have cooled down its almost at half.
  17. Acording to my local dealer there is no TSB issued on this matter...that is why i am asking members here for help.
  18. So I got the bulletin today. Is says in earlier models the transmission and torqu converter are to get replaced. Later models call for a shaft seal to be changed. Only refers to US models and US vins. My cayenne in canadian and from what i see its built in april 2003. Given that this just started happening i am assuming its just the seal. Any input on this guys? Shop manual calls for 7-9 hours for te re and re of te tranny.
  19. Is a TSB a recall as well? From the Glossary at the top right of any page: TSB Technical Service Bulletin. Porsche issues TSB's for part number changes, installation of options and accessories, approved oils, tires, wheels, etc. Recalls are NOT covered in TSB's. How do i find out what the bulletin says? I went to my l ocal dealer today and they claim not to know about it. But then again my local dealer is known to be a crook
  20. Can u explain what was the cause of this?
  21. this had to have happenned to someone else...
  22. R u refering me to a previous thread on the matter? is there a recall? what is the TSB?
  23. Hi guys, i just signed onto this forum. I just bought my Cayenne S last month and already started with the issues. Noticed that there was some tranny fluid leaking. Upon inspection today it looks like its coming from the front pump seal. It is dripping out of the treaded hole under the tranny near the bell housing. Has anyone ever experienced this problem? I don't wanna burn a tranny because of low fluid. Does anyone have a write up on how to remove the tranny so i can do the seal? How many hours to re and re these trannies? thanks...Mike
