lovethesport
    Other
    mercedes e430 4matic
    2005 porsche cayenne s
  • Future cars
    ferrari
    bmw x5 4.4
936 profile views
lovethesport's Achievements
  1. does it mean new maf---could cleaning them actually damage them----
  2. i just scanned my vehicle for codes and this one pops up----all info appreciated how to fix i did remove both the maf sensors and clean them with sensor kleen spray-----
  3. i want to take off my black trim and replace with silver as found in gts----pls advise on silver part no
  4. has any done this on a 2005 cayenne s i am thinking of doing this vehicle has 65k miles on it--- do you know part nos for the filter and the pan gasket----also how many ltrs of oil is needed any other tips/information is greatly appreciated thank you
  5. can anyone help with 2005 cayenne s----also should the bolts have any loctite on them while installing
  6. does any one have tips on how to remove the harness from horn----or do you have to cut wires
  7. my car alarm just went off----is the alarm horn same as the front horns----if yes what could it be
  8. the fuse is good---no 16 on left side fuse box----is there any relay----what else can i check ---thanks
  9. time too ad some bling to the 2005 cayenne s tire merchant recommends tires 265 35 22 should i go with this or what is a better size thanks in advance
  10. 2005cs--engine noise--dealer to replace under warranty with a remanufactured unit--- pls advise on the following;; 1::what is replaced along with engine::waterpump, starter, alternator, coolant etc 2::what type of warranty should they provide--the vehicle warranty itself will expire in 350 kms 3:::will this lower the resale value and is there any way to ask porsche for re-imbursement thanks you very much
  11. update---took the car into the dealer coils cracked--replaced--tech says all noises are ok------- service advisor listens and agrees there are noises and tech is wrong----- service manager is called---right away hears the sound---orders a bore inspection and advised of possible engine replacement under warranty---- will keep you posted if it turns out to be something else----
  12. Hey Bro, listening to the video it sounds like U may have some people stuck in ur engine......... may be the 1st problem!! Do u have any coolant leaking? That would be #1 for a water pump I would think. I had similar noise, but I also had coolant all over the place, may be ur water pump starting to go. I had about an inch of lateral movement in mine.....whoops Good luck! could it be the coils
  13. thanks very much---will they create a problem for me taking the coils out myself
  14. i had asked the dealer to look at this once before but the dealer says that there are no faults and no cel so he refused to inspect them...... i took them out and they end in part nos 002-----and they have hairline cracks---all eight of them----- the vehicle is going in for some engine noise issues on monday as warranty is ending in 400kms---- how do i get them to now replace these coils and will they give me hassle for taking them out myself or am i out of luck and they will not do anything
