vrichmd
vrichmd last won the day on November 6 2020
vrichmd had the most liked content!
About vrichmd
  • Birthday 10/19/1968
Contact Methods
  • MSN
    vrichmd@hotmail.com
  • Website URL
    http://
  • ICQ
    Daytona Beach, FL
    2003 Cayenne Turbo
1,545 profile views
vrichmd's Achievements
Community Answers
  1. I had to say goodbye to my 2003 Cayenne Turbo last week. A rear end collision in September led to it being totaled by insurance with over $13,000 USD in damage (see the "damage" below the bumper in the photo. I owned it for 15 years after my brother bought it brand new from Brumos Porsche in Jacksonville, FL. It's now owned by Progressive Insurance. If anyone knows how to find salvage cars after they're purchased by insurance, this one would be a good one to have. The VIN is WP1AC29P23LA90342. The car has ~171,000 miles and this year I replaced all the fuel injectors, both xenon headlight assemblies with Valeo aftermarket, both front ride height sensors, both mass air flow sensors, new cardan shaft, the HVAC center nozzle. Less than 1,500 miles since all that was done. Also, the tires have probably less than 5,000 miles on them. It kind of makes me feel like an organ donor, but I just hope someone gets good use out of it. I enjoyed (almost) every minute of it!
  2. See if these help. Some of the part numbers, may be superseded, but will give you a starting point. What I found after removing and replacing some are that they have a corresponding VW part number and are quite a bit cheaper if you buy the VW instead of Porsche...or at least that's how I found it several years ago when I worked on them. Here are the VW part #'s AC Servo motors (VW parts #) 7L0-907-511-AB front, defroster vent flap (1) $69 7L0-907-511-AD front, center left vent flap (3) $69 7L0-907-511-AE front, left vent flap (2) $70 7L0-907-511-AK front, left mixing flap (7) $78 7L0-907-511-AJ front, left footwell flap (8) $92 7L0-907-511-AL front, right mixing flap (10) $78 7L0-907-511-AM front, right foot well flap (11) $69 7L0-907-511-AG front, right vent flap (15) $69 7L0-907-511-AH front, center right vent flap (16) $69 7L0-907-511-AQ fresh air flap (13) $86 = 955 624 915 01
  3. My rear air struts are at "Special Terrain Level" height and the fronts have completely depressurized. I'm getting ready to begin work on the system and would like to depressurize the rear struts. Can the Durametric bleed the air struts like the Porsche tool? Is there an easier (or safer) way than breaking loose the air lines at the valve block by the compressor?
  4. Did you ever fix this? I've got the same issue and wondering what the solution is.
  5. I just replaced the center vent in my '03 CTT and there are what are called "blowing out sensors" in the center vent. I had already bought the part because the plastic dividers were broken, but before I replaced it, I started getting different temperature air from the left and right sides when the L/R temp settings were identical. The problem resolved itself with the center vent replacement, so I assume it actually had a bad sensor. The best piece of advice I can give for the overall "Cayenne Experience" is to buy a Porsche Service Manual online. They're all over the internet anywhere from free to about $15 for the PDF download. Best investment I made related to home repair and troubleshooting. The attached wiring diagram is from the 'WIRING' section which is 100+ wiring diagrams. The one I have is 60+ separate files totaling thousands of pages. Good luck!
  6. Check your flex disc first. I have an '03 CTT and what my late mother called a "leadfoot". I've replaced the cardan shaft/bearing assembly twice and recently thought it had gone again. Turned out to be the flex disc which had been replaced both times, but failed with only a few thousand miles on it.
  7. It turns out, the actual sensor itself isn't bad, one of the bushings of the ball and socket connector is completely gone.
  8. Getting the "Air Suspension Faulty Workshop" error message; scanned with Durametric and am getting Code 1769 - Vehicle level sensor front right and actual value is 0V where the other three are 2.4V. Fault comes back as soon as it's clear, so I'm thinking it's bad. I believe the correct part number is 955-341-076-21. What is involved in the calibration of a level sensor? Can it be done with a Durametric? As always, thanks in advance for any help.
  9. My '03 turbo with 165k miles doesn't smoke when running and doesn't use any more oil than spec. After I've been driving short distances around town, I'm in the neighborhood slowing to nearly a stop to make a turn after a couple of minutes of cruising 1800-2000 RPM in 3rd gear. All of a sudden white smoke pours out the exhaust; I'm not sure if it's one or both, but seems like more likely it's both. Anyone seen anything similar?
  10. I replaced that connector a few years ago, the seal was leaking so i was getting gas fumes in the interior and the gas had eroded the soft rubber. Make sure you've got a good pin removal tool and you should be in business.
  11. FIXED! I had to take it to my mechanic and he was puzzled after both batteries tested fine and removing the starter and it bench tested fine. Ultimately, he cleaned and tightened the power connection at the starter and the connection at the power distribution box and this fixed the problem. There was some corrosion on the starter connection and this connection came from the factory without a lock washer and wasn't completely tight. It did last 17 years, though.
  12. I got in my '03 CTT this morning and it would not start. I put the key in, got the normal lights and sounds and the starter wouldn't turn over at all. I can hear what I assume are the battery relays. Both batteries are fairly new, but I charged anyway, same result; tried to jump start, same result. I drove the car yesterday and no issues. The starter has been working perfectly, no dragging, or slow starts at all. Does this sound like the starter? Has anyone had the starter go bad suddenly with no prior warning? Any suggestions would be greatly appreciated before I have it towed to the shop.
