londoner06
Everything posted by londoner06
  1. There is a diagram of the different switches at this website: http://www.autoatlanta.com/model/986-97-04/903-05.htm You can talk to the folks at Sunset Imports, they can sort you out as well. You can find out more about Homelink and other garage door opener DIYs by going to 'Search' and entering: homelink This subject has been covered many times before so there should be a lot of info. Regards, Alex
  2. There's an alternator DIY here: http://www.renntech.org/forums/index.php?s...st&p=118847 You can also go to 'Search' and enter +alternator +replace It will pull all the threads that may be pertinent. Regards, Alex
  3. I do not think that there's enough slack. Of course you could 'lengthen' the wires. Also, the switches on the right all have their raised area to the right, the ones of the left to the left, the one switch would look awkward if moved to the opposite side. It's a Porsche after all, nothing is that far from the driver ;) Alex
  4. Thanks Ken. Alex Sorry, the reply came out 'in triplicate'
  5. I have seen the DIY threads for performing the amberectomy, I do want to double check this: • The piece that gets removed, as seen below (borrowed from Toolpants thread), which would be amber in my case, is just wedged in place, it's not glued in, correct?? • Is Xenonmods.com a good place to get the silver bulbs? I am thinking going the Dremel-with-the-wand route, attaching a small rubber hose to a vacumm to clean up afterwards. Alex
  6. Looking at 996 Porsche™ 'The Essential Companion' you may be right on both counts: • The 120 vs. 121 denotes RHD vs. LHD, the LHD ending in 0. • In the transmission code the 6th digit is 1 for 'open differential fitted' and 2 for 'limited slip differential fitted'. The transmission plate will have digits 7-11 for the serial number. The 0 may be the first number but I don't know the S/N of my car's transmission. Again, these are based on the 996 NOT the 997, so they could be wrong... Alex
  7. Michael, there are copies of the fuse assignments for different years here in case you need them: http://www.renntech.org/forums/index.php?s...ost&p=67481 Hope you get things working. Alex
  8. Here's a diagram for MY99 996: http://www.renntech.org/forums/index.php?s...ost&p=99259 If the window needs to be retrained check this post: http://www.renntech.org/forums/index.php?s...ost&p=92771 Alex
  9. Thanks Hobbes, it came right up. Alex
  10. Hobbes, excellent write-up! The kit, what brand did you go with, model #? I know H7 is the right size. I like the 'slim' fact so that it fits into the light housing, no need to pull wires and make holes in the housing, etc. Alex
  11. A: The whole 996 series bonnet/boot design leaves a lot to be desired! I had a 1990 C2 (964) with the sensible engine compartment release on the door near the latch and the usual bonnet release. You're lucky you don't have the silver handles, give Porsche™ some credit for redesigning those! Do remember the emergency bonnet opening procedure because if the battery goes dead you can't access the battery with electric releases. TIP: You can download a PDF manual from the 'Documents' menu. I find the PDF files so much easier to use since you can just use search to find what you need. Where in Blighty R U? Alex
  12. :welcome: First of all, it really helps to put the model and MY (model year) of your car on the post because there are so many variables. My car being a MY2000 has the silver handles (mechanical) to open the bonnet and the boot. Later models went electrical. There is a DIY thread here that covers removing the part that you seem to be talking about: http://www.renntech.org/forums/index.php?showtopic=7067 This part comes in different versions, depending on whether you have memory seats and of course if you have electrical release or mechanical. Of course I assume your car is RHD so you have to think 'mirror image' ;) Just FYI, there is a diagram on this page that shows all the different parts and part numbers: http://www.autoatlanta.com/model/996-99-05/807-03.htm At least in the US Porsche™ only sells the whole unit, #9 in the diagram, and it's pretty pricey. I had to hunt a lot to find just one handle. It's not a hard DIY, as long as you have the right tool to loosen the M6 x 25 hexagon socket head bolts. Anyway, welcome, Alex
  13. Orient, I have used it the 3M on the vinyl sun visors, it's safe on leather too??
  14. :welcome: Easiest thing is to do a search. Click search and enter: +engine +serial +number The subject has been covered many times before. Those look like these Carrera sideskirts: http://www.pelicanparts.com/catalog/shopca...tec996_pg24.htm Usually the letter X at the end of the engine part number means it is a rebuilt. Totally awesome ride, congrats. londoner06
  15. nstevo, I feel for you guy, OK, I have had very good luck with Meguiars products. You might give the ScratchX a try (usually available at Pep Boys or Autozone): You basically rub and rub until the product disappears and the finish looks shiny again. You can use it with a polisher like the Porter Cable to do whole sections, doing one section at a time: You have to work from lightest to strongest. The next product I've used is the Speed Glaze 80. It's a bit stronger than the ScratchX but still easy on the finish: I have found that hand applications are not as effective as using the Porter Cable, it really does a good job for applying wax/cleaners. Also you can call Meguiars and they can advise you over the phone. Good luck and let us know how it goes. Alex
  16. http://www.renntech.org/forums/index.php?s...k++plug++change
  17. Foster, the switches are not Porsche parts, look on the switches for a Audi/VW P/N, then google the number and I'm sure you can find a parts supplier online that sells them. Alex
  18. rexbd :welcome: • Here is a link to a hardtop lift: http://www.hoistlifts.com/porsche.html • In the forums section look for 996 series > 996 DIY and mods, lots of ideas there, like the 'spoiler switch DIY', the 'blinking side marker DIY', the 'daytime running lights' DIY, etc. • Washing/polishing suggestions here: http://www.renntech.org/forums/index.php?s...c=24205&hl= • Eric at http://www.bumperplugs.com/BPindex.html has lots of goodies to dress up your new Porsche™, I have bought from him a new Silver centre console, a new ignition switch 'rosette' and painted bumperettes ( I think yours are already painted) His work is flawless. • The front radiators need to be cleaned periodically, as well as the water drains, there are instructions for both in this website. Congrats again on your Porsche™ Alex
  19. Foster, here is a diagram of the dashboard trim from the PET, one is -01, the other 02-. Post the # of the part you are looking for. If it is #19 or 21 post the interior colour as well. Alex
  20. Grover, that's what I'd like to have, access to a lift, you're lucky indeed ;) I know in my 996 if I raise the car using the rear 'jack point' the front jack point raises to the point I can get a jack under it. I also use these ramps here to raise the car. A lift would be ideal but my garage is too smal to install one :( Alex
  21. Foster, what does this part do?? What does it control? Alex
  22. Joel, best thing is to do a search: +jack +points You'll find several threads on the subject Alex
  23. So has anybody used the 'DoorDefender' magnetic ding protectors?
  24. Has anyone tried the DoorDefender? WEBSITE: http://www.doordefender.com/home.html I realize it does not protect the car from vandalism like keying but looks like a clever product for protecting from parking lot dings. Alex
  25. Big_O, the boot removal has been covered before, if you put in: +shifter +remove you'll get a bunch of threads. I found this one that involves a 997: http://www.renntech.org/forums/index.php?s...shifter++remove There are sure to be others, hope it helps. Alex
