intubator
    2006 Cayman S
    1987 Carrera
    1968 911 S
    1983 911
    1974 914
intubator's Achievements
  1. Are you sure its the head sensor? I ask because the car will run with it dissconnected, but poorly if the engine is cold. The engine will not run if one of the other two are disconnected. Those are the speed and crank position sensors. Both located in the same general area but further up on the engine between the transmission.
  2. When this occurs check to see that both lock pins on the door top are depressing when locking. If one is not then the plastic ball linkage is likely off the pin and may be causing this. You have to take the door panel off of the one not depressing to inspect it.
  3. cylinder head temp sensor.
