clowntrigger
About clowntrigger
Contact Methods
  • Website URL
    http://teamseppuku.blogspot.com/
  • ICQ
    11019998
  • Yahoo
    clk68clk
    Greenville, SC, USA
    2002 911 C4 Cabriolet
    1999 BMW 323i
    1980 Honda CB750C free but not running yet
    1979 Toyota Celica GT Liftback - Destined for 24 Hours of Lemons
clowntrigger's Achievements
  1. I have a 2002 996 C4. The compression springs that hold the parking brake shoe against the wheel hub came loose and disintegrated inside the rotor. Everything else looks good, but I need to replace the compression springs. Is there a difference between the one used on the Boxster and 911? The springs for the 911 are about $30 each while the Boxster springs are around $10 each. 911: 99635274100 compression spring. PRESSURE SPRING. M008. 00-.2000 -2004- $26.19 Boxster: 98635274100 compression spring. PRESSURE SPRING. $8.53
  2. I have a 2002 996 C4. I replaced the front right cv boot. While mating the axle shaft to the carrier (or joint flange, see #2 below), the carrier pulled out of the differential. I pushed/banged it back in with a dead blow and all seemed well. After a few days, I noticed the car was leaking in the front. I put it on stands and saw the carrier had backed out again. I pulled the front axle and went through the same procedure. Another week and same results. I've got the front axle out again. The circlip (#4 below) on mine is not a full circle. Did I damage the circlip and need to replace it? Should the carrier only come out of the differential if the differential is dropped and disassembled? Here's what mine looks like. Any help would be appreciated.
  3. I didn't notice anything until mine failed.
  4. Is there a wiring diagram I can get for this circuit? I've checked the pads and sensors several times and they're in good shape. The break has to exist somewhere else and I'd like to track this down and resolve it.
  5. I traced the wires from the actual brake pads to where they plugged into the harness.There is a single wire that runs from the harness to the brakes and it runs in series from one pad to the next at each wheel. My guess is the wire is broken somewhere in the car harness.
  6. I am getting the Brake Wear service wear on brake pads warning. I pulled all four wheels and checked that the pads had plenty of life. I also checked continuity across the sensor and they all read 0 ohms, so there are no shorts. What else can I check to track this down? 2002 996 C4 Cab
  7. Is there any way to print the pdf? It's password protected.
  8. Well, my handiwork only lasted about 6 weeks. I bought a used switch that works from a salvage vehicle. We'll see how well it does long term.
  9. And it worked for me too. I pulled it apart and hit the contacts with 600 grit sandpaper. I lightly buffed each one. I was able to put it back together with a chisel pushing the tabs back in. most of the broke off, so i did the edges.
  10. Thanks, I missed that in my search on fog lamps. This will save me on the cost of another bulb.
  11. My right rear fog lamp is not working. I am not getting voltage at the wiring harness connector on the car side where the lamp assembly plugs in. The wire combo is brown (ground) and gray (power). Where are some test points on the car harness that I can test to track this down?
  12. This was also tracked in another post. I didn't realize at the time the were related. The problem was from a failed motor mount. I replaced them with some cheap ebay mounts and one of them failed less than a month later. I replaced them with oem parts and haven't had any problems in months. The cheap ebay mounts were not hydraulically filled. My recommendation is to buy from a known vendor like Pelican Parts, as getting any customer service from ebay or the seller was a PITA.
  13. The problem was from a failed motor mount. I replaced them with some cheap ebay mounts and one of them failed less than a month later. I replaced them with oem parts and haven't had any problems in months. The cheap ebay mounts were not hydraulically filled. My recommendation is to buy from a known vendor like Pelican Parts, as getting any customer service from ebay or the seller was a PITA.
  14. I bought both the inner and outer boots from Pelican Parts. They both came with clamps, even though the inner did not specify clamps. Now to get a free weekend to install them.
  15. Is there a generic boot that can be used for the front outer cv boot? The inner boots aren't expensive, but the outer boots are over 2x the cost of the inner. The inner boot comes with the clamps and the outer boot does not. Is there a part number for the clamps or does anyone know the sizes needed? This is for a 2002 996 C4. Edit: Ack, looks like I posted this in the 997 forums. Can an admin move this to the 996 forum?
