timm996
Everything posted by timm996
  1. did you ever sort this problem i have something similar
  2. hi - looking at your tapping in idle post - mine does the same, and stops in drive or reverse. Just had a full engine rebuild.. still does it - did you get yours sorted?
    Read more
  3. I need some cats, but I find that I can buy a s/h turbo exhaust and cats for less than half the price of a standard 996 exhaust. So has anyone fitted a turbo exhaust and cats to a non turbo? Can it be fitted with adaptor tubes or flexy joints? Without having one to fit up I dont know how far the headers are from the cat flange. Any help would be appreciated..
  4. thanks, i had the wheel off, but I see what you mean about the weight, I will try putting something under it to take the weight off it, thanks. I was feeling rather smug after replacing my spark plug coils and to be beaten by a simple job of removing a bolt was too much :huh:
  5. Trying to change this, also called the anti roll bar link here in the uk Cant get it out of the wheel hub part. It should be easy, remove two nuts and take out.... but top part just stuck, Tried whacking with a club hammer so it resembles a mushroom, but still stuck.... anyone else got one out? part in question
