911Spdstr
Everything posted by 911Spdstr
  1. Does anyone have the part# for the brackets needed to mount the left and right roof rail on a Cayenne? I think there are six total and is position sensitive. The special set screws as well. Thanks in advance, Jonathan
  2. Thank you for the info. I will use a PIWIS to confirm.
  3. I use a generic OBDII scanner which gave code P0387 and eventually lead to P0389 if I remember correctly which when refer to the code book show Fuel Temperature Sensor B Circuit Intermittent and Fuel Temperature Sensor B Circuit Faults. Just did coolent pipe change and this start to pop up. Reset but come back every few hundred miles.
  4. Where is this located? I have a P0187 Fuel Temperature Sensor B Circuit Intermittent and wanted to check the connections and/or replace the sensor. Thank you in advance for any info. Regards, Jonathan
  5. Looks that way - I was able to remove the front piece and lower trip easily. But the metal part of the rocker panels are really on there tight - just don't want to damage the quarter panel in the process... Appreciate any quidance / trick to do this right. Regards, Jonathan
  6. Does anyone know or have diagram that show how to remove rocker panels from a 993TT? Thanks in advance, Jonathan
  7. Does anyone know where I can get the rear bumper exhaust cutout trim pieces (left & right)? Regards, Jonathan
