XLR82XS
Everything posted by XLR82XS
  1. I have the entire front end of my 996TT in Xpel Ultimate and it is the bomb! Fantastic film and fantastic warranty.
  2. Ditto - it is a door latch failure.
  3. 295 to 315 will not upset the AWD. It's a minimal increase and not a large increase in overall diameter.
  4. Rear bumper only, dry pavement.
  5. No oil leaks, normal consumption and no oil smell anywhere. Exhaust tips get black/dirty as they have before under extensive use.
  6. Spoilers are dry. It's the color of oil and feels like oil. Small drops that look like they were "misted" on with a spray bottle. It is spread all over the bumper cover and decklid/tail lights. I'll snap a photo next time im at the car.
  7. I am seeing what seems to be small oil droplet deposits on my rear bumper and decklid after a long drive. Oil level good, no leaks anywhere, brand new turbos. 2002MY with cat-less Speedtech X-flow and EPL program. Has anyone experienced this?
  8. No more M1 0w40. A 25-year Porsche tech suggested Pentosin 5w40 and ever since I switched no more occasional smoke on startup and runs great.
  9. If planning to change your accumulator upgrade to the GT2 slave conversion kit that deletes it. EVO and SpeedTech both sell kits.
  10. Bought my car with 2 of those keys and same keychains. GREAT upgrade! Thanks PO! :thankyou:
  11. After buying all the parts you need (flanges, piping, clamps, mufflers/resonators) plus measuring, cutting, welding, fitting, etc.... You're better off purchasing a SpeedTech system which is an outstanding system and one of the best priced systems on the market. I'm not messing with it as John has already done so and builds one of the best systems out there.
  12. 2nd gear pop-out, MAF sensors blowing plus the downfalls on the 01's noted above. Just look for the normal stuff any try to get maint. records.
  13. Re-soldered in a new resistor and re-installed. Works perfectly.
  14. Found the problem. Broken resistor(?) at the light. The 7-8" harness has 2 LEDs (ignition & handle) that are on the same circuit. Soldered in a new resistor and will install ASAP. Hope it works.
  15. I guess the door is coming apart then. ****... Gotta a rattle in the passenger door so both are coming off.
  16. Searched and found nothing. How do I remove/replace the tiny bulb in the door pull that lights up the igniton when lights are on?
  17. 86K 02 C4 cab. (3.6L) Runs strong.
