superman_006
Everything posted by superman_006
  1. Well the thinner bearing wont work... the inner shaft has a shoulder on it that the same thickness as the bearing.... Its so it secures the inner race of the bearing. It still makes the noise and I am starting to think its the water pump. When I spin the water pump by hand it doesnt make any noise, It doesnt seem to have much play in the shaft. I took some videos of the engine running with/ without the belt on. You should be able to click on the pic and the video will pop up
  2. OK... Well I took the air box out and ran the engine for a few mins..... I could feel the noise most when i put my finger on the bolt for the lowest idler pully. I took the belt off and NO noise. I turn all of the pullyes by and and they feel fine. Are these bearings "serviceable"? I took both the idler pullyes off and they messure out ther same, one bearing says s-74 and the other says s-79 (i think). I went to a local bearing distributor and bought 2 for about $7 that have the same ID and OD as the factory bearings however the thickness is about 4mm thinner. The guy there seemed to belive that the bearings he sold me would definatly work and they have a 1 year warrant. I can spin the OEM pullly in my hand and it doesnt seem to make any noises and feels smooth, so Im not 100% sure yet.
  3. Ive only put 800 - 1000 miles on it since I got it. I have beaten on the exhaust with the car off and it up in the air. I am going to video it and try to post it on here to see what you all think. It does sound more like a waterpump or an idler pully to me. I also counldt feel the noise anywhere on the engine or any other the acc i could touch
  4. Well after searching more..... Its looking like a trans pull, then pull the clutch and flywheel. Are these IMS bearing "upgrades".... really upgrades? If so which ones are the best ones?
  5. Well my 99' 996 C2 has about 42k on it. when I first got it about 2 years ago it sounded like it had rattle in the muffler. Its worse now, it starting to sound like my old 914. I have been online searching into the motor noises..... and everything sounds like the intermediate shaft but mine sounds like its comming from the front of the engine (rear of the car) . So I am not sure if its this shaft or an acc pully. In a lot of the articals.....people are talking about removing some cover. Is this with the motor in? I have also seen a bunch of pics with bolts broke off, but all those pics are super close. Does this shaft stick out both ends of the engine? Do I have to pull the engine out to replace the bearing? My climate control also started bleeding and on the DIY section, they have a link for just the LCD but its a bad link. Anyone got a new link?
  6. Which switch the dash or the column?, I reset the CEL and put about 400 miles on it with no light, I am hoping its where the car was sitting for 8 months or so, It came on within 20 mins of driving
  7. I have no idea what weight of oil is in it, but the oil looks brand new on the stick.... I am going to call the dealer i got it from today and find out.
  8. Visually then with an multi-meter
  9. OK... more questions after starting my car with the windows down in the garage. When I start my car I can hear the lifters for the 1st second or two. Is this pretty normal or should I change the oil to make sure I have to correct oil in it?
  10. OK, got the "PARK" light working, I pulled the cover off the side of the console, and the brown wire feeding the handbrake switch, looks like it was never put into the wire hold down and got rubbed in half by the hand brake over the years, I put it back together and into the hold down ........ WORKs now!!
  11. or more likely the bulb is burnt out in the cluster. The light comes on when I first turn the key on, I think it the 3rd one over from the left, it goes off when I start the car Also whats the 1st light on the left, its pointing the rear hatch, it stays on untill the car moves?
  12. Thank you guy very much. When I apply the parking brake, the light never comes on.... I am going to guess the swith for the parking brake is just stuck.
  13. I just bought a 1999 996 today 41,000 miles And it has a few minor thing done to it, and I have NO owners manual 1) the heater/AC fan doesnt seem to blow very hard, I am assuming its coing to need a need cabin filter, I found the DIY artical already 2) My interval wipper, i cant change the speed, the knob doesnt do anything.... I may need help on the diagnosis 3) I have sevral questions concerning the auto spoiler, Mine seems to have a one touch up, but I have to hold it down to get it to come all the way down, "Is that normal?" Once I have the spoiler up and I reach 50mph or 70mph it will go back down, "Is this Normal?" 4)The engine light came on and I got 3 codes (p0420, p1124, p1126), I am hoping they all related to just one part 5)Are the 1999 fog and headlights HID or hylogen? 6)If I have aftermarket 18" wheels should I run the air pressure staggard (front to rear) like porsche does with their OEM 18's? 7) my dummy light for the "park" light doesnt come on when the brake is pulled though it comes on as soon as I start the car. 8) where the clock is, when I just turn the key to on (not running). What the small digital gauge?
