skullbocks
Everything posted by skullbocks
  1. Hi, I'm having those two code making the CEL coming on and off, but was mostly on. I'm able to heard the air pump on cold start. I planned to change the air filter, so in the mean time i also cleaned the MAF sensor with electronic spray. performed those maintenance : 1- replace air filter with K&N 2- clean MAF sensor (it seemed pretty clean, not oily ) 3- remove the snorkle from the side intake vent. Car : Porsche boxster 986 98"
  2. Hi, i did install a brand HID 8000k headlight kit on my 986 boxster couple of weeks ago, and i notive that once i switch the low beans on, the radio turn off/on (restart) I just wonder if anyone already have this problem ? thanks for your time.
  3. Hi, I would like to have some advise on how improving the engine sound on a Boxster 98. 1- Is a performance air intake improve sound or only perf ? 2 -have you some suggestion on a muffler ? 3- i bought this header on ebay : http://cgi.ebay.com/ebaymotors/ws/eBayISAP...em=270328380132 Any feedback on those aftermarket header ? thank you for your time.
  4. thank you guys !!! you make me save $300 ...
  5. Vehicule : Porsche BOXSTER 98 Hi, Sometimes , i heard briefly an odd flywheel noise right after the engine start. The dealer told me that in my case sometimes, the ignition switch keep sendind for some milisecond electrical juice even after the engine start, resulting this flywheel noise. They told me they need to change the " ignition switch electrical part" and quote $350 !! So i was wondering if anyone already have that happend and if by "ignition switch electrical part" they meant just change the ignition switch, job that i can do myself for cheap, or they meant the wire as well ? I dont have lots of knowledge on that part of car, so if they really a wire part after the ignition switch or should i try anyway to change it ? Thank you for your time
