ronbonner
Everything posted by ronbonner
  1. I just done a search and found a similar post last year so there is a lesson here. DO A SEARCH FIRST!!! RB
  2. Hello all, Has anyone suffered a loss of all the audible warning noises from the dash? or does anyone have any idea why, on my daughters 04 S there are no warning sounds for the lights left on, indicators, temperature or low fuel etc. She has been told it will cost circa $2000 to fix by a non Porsche shop and naturally she has concerns so she turned to her old Pops who now hopes someone here can make me look good here!!! Thanks RB
  3. Hell all, Can anyone point me in the direction of a supplier of the Dension Gateway 500. My son in law wants one and is going to take advantage of the cheaper prices in the USA so would like a name of a supplier that will get the unit sent to his West Florida address. Your suggestions are warmly welcomed Thanks guys
  4. That's normal, Alex So the Stigs first name is DC then????
  5. A huge sigh of relif on your part no doubt!!! Glad it turned out OK in the end Use a new version of the old carpenters mantra next time - Check twice drill once!!!! RB
  6. Loren, Do you reckon the guy might need to know about the two bolts on the wheel to undo first?
  7. Cheers Gundo, Handy tip I will try this next time, RB
  8. This I don't know as I said I can't access the config anymore (I will try again when I install the next update) If you do manage to configure it so the selection is made without "turning a page" then let me know how and if I ever do get the config up again I can change. Turning the pages is the one bug bear I could do without. RB
  9. Action, I have the Dension 500 and I have at times, had display issues with the unit and Ipod. the latest update has helped but I do "loose" the data on the screen from time to time. When I say loose I mean that the menus don't configure correctly. At first I thought I may have misunderstood the very poor instructions and configured the text incorrectly and I tried to access the Config by the 6 x switch operation. I simply can't access that config anymore for some reason. Having said that I don't seem to suffer with loss of the screen data anywhere near as much as before and things have settled down nicely now. I have the same screen as Berty and like his my main text is through Disc 5 If you have your screen on Disc 5 I would say you don't need to re-config as the way I understand the instructions is that this is the preferred position for PCM. RB
  10. Nice one Paul, Glad you sorted the codes out. I had a similar experience down here in the sarff with my code. Keep your eyes open on ebay for a nav disc. RB
  11. Paul, I had a 996 with PCM 1 (8 bit) which given your year was the same as my car yours will be 8 bit too. I seem to remember needing two codes. One for the Nav and one for the PCM. You don't say if you have two codes? RB
  12. Andy, I think what maurice is looking for is this touble shooting guide I put together some years back. Its a way to test the operation of the microswitches that sequentially operate when you press the button to put the top up or down. The idea is you test each circuit until you find the switch that is not operating. Favorites to give problems are the parking brake switch or the switch in the roof hook recepticle. Anyway try this link to the guide but you will need a voltmeter but don't worry if you never used one as I have a diagram showing where things go and when. Hope you find the problem http://www.renntech.org/forums/index.php?a...st&id=11249
  13. I have done my own and I never come across the need to do that. I have just checked Lorens instructions on changing rotors and there's no mention of having to carry out that job there. I have had no trouble and I am predicting you won't RB
  14. Cheers Richard, That will teach me to to go you know where first!!!!! RB
  15. Happens to me too on my 04 C4S - I took out my Nav Disc and the sound changed to even noiser the next time it happen so I am convinced it is something to do with the CD. I have not suffered any degrodation in the PCM performance as of yet and the noise has been happening for at least 6 months. RB I just noticed on reading the posts again - am I the only one with PCM that this happens to?
  16. Got the chance of fitting a telphone handset into my MY2004 C4S Tip Cab with PCM2. The handset comes from a MY2002 pre face lift Boxster connected to a PCM1. Can I do a straight swop or are there two versions of the handset? Anyone know? TIA RB
  17. Thanks TP, It is exactly that, the buttons look like the previous owner had a nervous disposition and used the key to repress his anxeity by chewing on the them. He did so it much that they are dificult to press. Could have been whilst waiting for his service bill in a UK OPC. And thanks again Loren for the tip regarding alternative assistance from other speacialist. RB
  18. Thanks Loren, I have a My2004 4S Cab so I expect the key will be the expensive one with the top and trunk buttons onboard. So 100 bucks for the key and another 100 bucks for the programming thats $200 coverted into UK pounds £100 - this is an expensive repair for a key as I am not to confident that the OPC here won't be more than $100. I gonna ask the PCGB if anyone has had it done recently. Anyway thanks again RB
  19. have you tried Sunset Imports (Porsche Parts at Dealer Cost)? They sell just the heads for $88.45— $105.55 Loren, Excuse my ignorance regarding the keys but If I have a "chewed" head of my key can I simply buy a replacement head and do a swop? If so how does all the coding stuff work? Thanks RB
  20. There are a series of simple voltage tests you can do if you have a volt meter. All is explained in the troubleshooting guide attached to the post below Check out http://www.renntech.org/forums/index.php?showtopic=18477 which covers the same issues you have (and I had once upon a time) RB
  21. Sorry Gert, Been away on business so didn't get to see your post. I will look at your configuration on my GW this week-end and see if I can re-create your issue to see if it is the same for me. Ron Had time to have a look this evening and this is what i was able to see. From the CD list menu I chose menu but I do not see ABC Search anywhere? RB Thanks for looking! After choosing menu, there should be a lot of options, such as source, songs, playlists and so on. If you go to songs then, ABC Search should be offered. Anyway, after you have chosen menu, and go go to track view, what is the first highlighted item? Can you choose this by pushing the knob? Yes I can, I see the first song on that particullar list. I can highlight any track by spining the right hand button to my desired choice and just leave it highlighted and in a very short while it will automatically be chosen by the GW and play or I can turn the button to the required track and just press the button once and the track plays immediately. I take it this isn't how yours operates?
  22. Sorry Gert, Been away on business so didn't get to see your post. I will look at your configuration on my GW this week-end and see if I can re-create your issue to see if it is the same for me. Ron Had time to have a look this evening and this is what i was able to see. From the CD list menu I chose menu but I do not see ABC Search anywhere? RB
  23. Sorry Gert, Been away on business so didn't get to see your post. I will look at your configuration on my GW this week-end and see if I can re-create your issue to see if it is the same for me. Ron
