Monodose
Everything posted by Monodose
  1. Mine does the same thing as well Same here and it is normal
  2. Monodose
    Too much fun
    Hell yes, I enjoy it to the max
  3. I was just told by the mechanic handling my car that the rear RHS is slightly leaking and he recomended upgrading to PSS9 (PSS9 Coilver Suspension Kit "club-Sport") http://www.fvd.us/shop/picture.php?VID=147...0996GT301_1.jpg Wondering whats your input about this? Is there something better that you recommend from experience? Cheers Monodose
  4. I run 25psi (1.723 bar) cold on the fronts and 23psi (1.585 bar) on the rears in my MK1 but I use semi slicks. I usually run around 30psi hot and modify it accordingly on the track
  5. Monodose
    MK1 GT3 pics
    Thanks :) No didnt check it, would you want to move this post?
  6. Monodose
    MK1 GT3 pics
  7. Monodose
    mk1 flywheel
    The CS might, as you say, have a different flywheel than the cupcars. Here is qoute from a british site: The Clubsport version comes with a bolt-in roll cage, fire extinguisher, bucket seats and single mass flywheel (notice the noise when depressing the clutch whilst stationary). Emergency cut-off switches, one under the bonnet and one in front of the gear lever. These are for track use only and the external red pull loop is normally stored under the luggage compartment lid. Found here: http://www.titanic.co.uk/GT3/GT32e.htm Edit: More info in this buying guide: http://www.parr-uk.co.uk/parr-media/996-gt...-compressed.pdf This is exactly what my MK1 clubsport has
