20031118
    2001 c4
  • Future cars
20031118's Achievements
  1. my car is 2001 c4 manual . i want to change Gear oil and manual transmission fluid ( some like gearbox oil ???) this two can buy from porsche ? how many i need put in the car - Gear and Manual transmission fluid ???
  2. ma car is 2001 c4 , very slowly , mean's i need take 10-15 minutes to driving around town , the thermostat coming 190F~ it's normal ??
  3. any one have advice for this , when i start at morning ( or car is cold ) the temperature is comming very slowly , maybe is water pump ?
  4. thank you james, i will follow your way try to fix this ...
  5. thank you ~ i will find a shop. i want to know . if i didn't fix this . have any problem there ? because it's one year ago................( i never know have problem with fan....) i have make appointment with porsche. but only one in the toronto area... the date- JUN 7 ,2008 ~ i don't like waiting for long time ~ every advice is very importance ~
  6. Toronto, canda ~ PST OR PIWIS means comupter ? check the fan ?
  7. i check the Radiator Fan fuse and relays both ok..... i try to stage 2...(turn the AC on)...... the high speed fan not working.... so..what i need to do next ... thanks ~
  8. forget one thing...... where is the relays..... In the footwell, above and to the right of the fuse compartment. There will be 4 relays in a row, all the same type. Sockets 19, 20, 21 and 22. I am going through the same thing. I removed the right radiator fan last night. With a VOM, I read 2.43 megohms resistance through both leads on the ballast resistor which explains why the fan did not work. Now I am looking at the fan itself. Not a bad job to do, just get the car about 8-10 inches off the ground and keep track of all the different types of fasteners and locations. It took me about 1 hour to get the car in the air, remove the right wheel, wheel well liner, front bumper and get the radiator fan out. You can clean the ductwork at the same time. Good luck James Greer thanks for your advice , i will go to a bodyshop do this work next week . and also my car have some shake ... anyone know what's wrong~~~
  9. forget one thing...... where is the relays.....
  10. thank you ~~ if the fan ballast resister~ how to fix it.... if i change the spark plug...do i need change the ignition wires or other parts~ thank you very much ~~
  11. :) my car is 2001 c4. 45000 miles. my driver side Radiator Fan is not working~ i check the fuse. it's good~ have any advice ? also if i want to clean up radiator fan ....how can i take the front bump out~ if i need replacement the spark plugs. do i need take the rear bump ? thank for any help ~~~
