Highlander
Everything posted by Highlander
  1. I'd suggest sticking with OE parts. You know they work.
  2. Could simply be a slightly loose swaybar droplink mount. Check that the droplink is torqued correctly on the swaybar. You can find how to do that here: http://gwl.rmsolo.org/hacks/suspension/index.html To answer your original question, yes you can simply swap struts left to right, they are identical. Good Luck, Graeme
  3. The general consensus is to use a cocktail of 2 Redline fluids: 2 parts 75W/90 NS 1 part Lightweight Gear Oil I use this in my B&M short shifter equipped "S" and it improved the shift quality considerably. It's still a little notchy when it's cold, but way better than with the stock Porsche fluid. Good Luck, Graeme
  4. Excellent! Thanks for the update. :clapping:
  5. Not a quick solution, but try a cigarette lighter plug-in battery tender and see if it will charge the battery enough to at least open the hood. G
  6. Get someone to push down on the hood just below the emblem as you pull the emergency release cable. That should help reduce the tension on the latch and make it easier to open. Good Luck, Graeme
  7. Stock 18" fitment on the 986 is 225/40-18 on 8Jx18 ET 50 and 265/35-18 on 9Jx18 ET 52. However, I am running 9Jx17 ET 43 on the rear of my car and they fit fine. The tire sizes for the 987 are a little taller than the 986 to allow the use of practical sidewall heights with 19" wheels. The 18" 987 wheels should fit your car without any rubbing. If they do rub, it will be very minor and can be fixed by adding a 2 or 3mm spacer. Please post pictures and whether you needed spacers or not here if you go ahead. Good luck, Graeme
  8. What you are feeling is another symptom of worn out shocks. As the shocks wear, their ability to dampen out bumps reduces, causing a very harsh ride. Replacing them will almost certainly improve your ride considerably. Graeme
  9. I'm in 100% agreement here. The OEM pads may be a little more expensive - especially if you use board sponsor Sunset Imports - but they work very well, are quiet and are relatively low dust.
  10. There is a great writeup on Boxster brake replacement put together by Trygve Isaacson here: http://www.bombaydigital.com/boxster/projects/brakes/ Good Luck, Graeme
  11. It's pretty easy to do yourself http://www.bombaydigital.com/boxster/projects/brakes/ If you can't do it yourself, either use the dealer or an independent that works on Porsche's. Good Luck, Graeme
  12. Hmmm, I wasn't aware there was any calibration that could be done. My speedometer consistently reads ~3mph high. If the dealer manages to successfully calibrate your speedo, please report back. Good Luck, Graeme
  13. Yes they are Brembo and yes, they are monoblock. If this is a college project, call your local dealer and ask them if you can observe a brake job and take some measurements. I'm sure they'll help you out. Good Luck, Graeme
  14. In principal, he is absolutely accurate - if you are aligning a formula car where all those things are adjustable. On your Boxster, you can set toe and camber. That's it. Ackerman and caster are what you get. There is no way to adjust either on our cars. Find your local SCCA autocrossers and get a recommendation from them. Good Luck, Graeme
  15. Find someone who will do custom alignments. You do not want the "it's within factory specs" kind of cr@p. Front: Toe - as close to 0 as you can get. Camber - Max negative, but matched left to right. Probably around -1 degrees is all you'll get with the ROW suspension. If you find your front tires wearing heavily on the inside edge, try flipping them on the rims before the tread has totally gone. If you still find they wear too fast, reduce the camber. Rear: Toe - 1/8" total toe-in a Camber - 0.5 degrees more camber than you got up front. eg, if you get -0.8 degrees up front, set the rears to -1.3. This is a nice aggressive street setting. If you find the car tramlining badly - ie following the ruts in the road left by heavy traffic - try adding a little toe-in. Good Luck, Graeme
  16. What is your tolerance for buckboard stiff suspensions and replacing tires? The only reason to get a coilover suspension is to gain the camber we need to the track and to stiffen everything up so it improves the handling. To run adequate camber for track or autocross (-2-2.5 degrees), you will go through a set of tires in less than 5k miles! For a predominantly street driven car that sees the track and Ax course only occasionally, it's hard to recommend anything other than the ROW M030. Even "spirited" runs in the canyons would be more than satisfied with the ROW setup. Of course, as always, this is IMHO. Graeme
  17. Technically, the stock suspension on a Boxster is a coilover since the shock assembly mounts through the spring. However, the term "Coilover" is typically used when a suspension has adjustable ride height. Normally this is achieved with a threaded shock body like the PSS9 and H&R Coilover systems. You don't mention your location. Here in the US, a popular upgrade is to install an ROW M030 (Rest of World, Sport tuned) suspension. If you are not located in the US and your car does not have the M030 suspension, that is probably your best bet. If you go that route, I would also recommend upgrading your swaybars to the M030 bars too. If you drive your car 100% on the street, I would recommend simply replacing your suspension with either OEM or aftermarket stock replacement parts. Bilstein has a couple of standard shock replacements as well as their PSS9 system you mentioned. I would be hard pressed to recommend a coilover system unless you are autocrossing or tracking our car. Even at their softest settings, you may find the ride a little harsh. Good Luck, Graeme
  18. I drove my car for about a week with the MAF disconnected while a replacement was shipped. It was summer so it was quite warm. Other than the glowing check engine light I didn't notice any difference. I'm pretty sure I would not have passed emissions, but it did not effect driveability at all. Graeme
  19. There is no set amount. Just contribute what you feel is fair based on the help you have received. Once you do, you will receive the prestigious title of "Contributing Member" :) Graeme
  20. Definitely replace all 4 corners. Does you car have the M030 "Sport Tuned Suspension"? If not, then that is probably your best bet. Great prices from board sponsor Sunset Imports http://www.renntech.org/forums/index.php?a...amp;code=sunset Give 'em a call and tell them you heard about them on RennTech. If you go that route and can rustle up the $$, upgrade to the M030 swaybars too. Another option is the ROW M030 (ROW stands for Rest of World). This lowers the car around 1/2" and stiffens things up a little more than the US 030. A complete kit can be purchased from Carnewal in Belgium for around US$1200 http://www.carnewal-europe.com/cpx_p86003.htm Good Luck, Graeme
  21. Thanks - you are too kind... :cheers: Graeme
  22. This is the picture I find most interesting. http://www.renntech.org/forums/index.php?a...ost&id=6081 With the JIC (branded Cross in the US) setup I installed on my car, I have more rear camber than I want. These guys have actually understood this is a problem with lowered Boxsters and have made allowance for it by giving you 3 camber settings on the rear upper strut mount. Now why can't JIC and Bilstein do the same? I'm going to have to look into what it would take to get something like that fabbed up. Graeme
  23. Stock suspension? Any funny noises?
  24. Just replacing the wheels with 17's and picking a tire with a reasonably soft sidewall will soften the ride considerably. Good Luck, Graeme
  25. Please report back on how well the HF tool worked. thanks, Graeme
