Highlander
Everything posted by Highlander
  1. Everything looks pretty straightforward except removing the hose clamp. I do not own a set of hose clamp pliers. My philosophy on buying tools is this: I take the labor charge if I were to have the dealer do it and use that as my tool budget. With that in mind. Can anyone who has done this job recommend a set of hose clamp pliers for me. Thanks.
  2. Ding, ding, ding, we have a winner! A few threads can protrude through the hub and collect dirt/grime (they have an anti-corrosion coating that has survived many Colorado winters on my car, so corrosion shouldn't be a big problem). If you simply unscrew the bolt, the dirt/grime messes up the nice soft aluminum threads in the hub. You should always clean any protruding threads prior to removing the calipers. Thanks for bringing this up, I'm just about to put the stock suspension back on my car had had forgotten about this potential problem. Your pain might just have saved me some. THANKS!!! :cheers:
  3. Trust the sensors. Unlike some manufacturers, Porsche fits a sensor to each and every pad. If the brake wear indicator is not illuminated, they are unlikely to be completely worn out. By al means do a visual inspection, but it's highly unlikely your squeak is being caused by the pad backing plate contacting the rotor. Good Luck
  4. What is the offset on the rear wheels?
  5. Yup, that's the right one. I just had to use one of those yesterday. It does work, but it is more difficult to seat on the balljoint. Also, you have to be sure to leave the nut screwed on the balljoint so the top of the threaded shaft is level with the top of the nut. Good Luck
  6. Part #'s for US/Canada suspension parts are the same, so there will be no difference in ride height.
  7. It's more likely a small rock got caught up in the dust shield. It's not an infrequent occurence, but it is kinda worrysome when it happens. Glad you got it all fixed.
  8. I drove to the event on RE050's ;) Hoosier A6's for competition runs though. I actually had TTD for about a minute... until a GT2 in the Modified class stole my thunder. Then when the Improved cars came out, I dropped down a few more spots.
  9. Give board sponsor Sunset Imports a call before you go aftermarket. You might be pleasantly surprised. http://www.sunsetimports.com/porscheatcost.php
  10. That is the exact tire I'm running on my '01 S in 225/40-17 and 255/40-17 sizes. I really like them. I have even run them on the track a couple of times and while they are obviously a street tire, they performed remarkably well. Go for it. Oops, typo! :eek: Fronts are 225/45-17.
  11. That is the exact tire I'm running on my '01 S in 225/40-17 and 255/40-17 sizes. I really like them. I have even run them on the track a couple of times and while they are obviously a street tire, they performed remarkably well. Go for it.
  12. Dummmmb question do you have a illustration on how to use the tool please Here's a pic from my suspension R&R (http://gwl.rmsolo.org/hacks/suspension):
  13. Is your current alignment off? You do not need an alignment if all you did is change wheel/tire sizes. If you do need an alignment, your answers to the following questions will help determine what you should ask for. 1. What is your primary use of the car? Commuting? "Spirited" canyon driving? Autocross? Track? 2. What is your tolerance to uneven/high tire wear? 3. Will you trade tire wear for better handling?
  14. 19" wheels are an aesthetic modification. If you like the look of your car with 19's, I say "go for it". I would suspect however that ride quality will suffer because of the ultra low sidewall height. Porsche increased the rolling circumference of the 987/997 models to allow 19" wheels with reasonable sidewall height. I'd guess the reason for the suspension "strengthening" is a combination of a heavier wheel, higher rotational inertia and increased impact loads due to the shorter/stiffer sidewall. Good luck
  15. Humming noise... rattling... My bet is a bad bearing. Pretty easy to diagnose. Lift the right side of the car and spin the wheel. It shoud be smooth and quiet. If you can feel roughness, definitely bearing. The old fashioned "wiggle the tire" may not show anything. Good Luck
  16. Yup, that's exactly what it's for.
  17. Good advice from Mike about getting used 16" take-offs. For tires, I have had great success with Nokian WR's and Gislaved Nord Frost 5's on my BMW's - my Boxster gets racing slicks, not snow tires :D http://tinyurl.com/299vp2 http://tinyurl.com/bhwj7 Both of these tires give decent dry and wet weather performance - for a snow tire - as well as exceptional snow performance. I have also tried Michelin Pilot Alpins and was very disappointed in them. Felt like I was driving on marshmallows in the dry and their snow performance was only mediocre. The Bridgestone Blizzak WS-60 is another exceptional snow tire, but has only mediocre dry performance and does not wear well if driven predominantly on dry roads. Good Luck
  18. Yup, you need more camber. The "factory alignment" on my car straight off the boat had POSITIVE camber on the right, 0 camber on the left and a whole bunch of toe-out. Porsche must have thought I wanted to go circle track racing... Either the ROW or PSS9's will help your camber problem at the track without compromising your street wear too much. Do not use camber plates on an otherwise stock suspension. It kills the handling of the car. Ask me how I know!!! <_< GT3 control are work but as you said, they are expensive. Dremelling out the upper mounts? That's a complete hack. Can't recommend it. What I would recommend are the PSS9's as they give you the ability to corner balance your car and you can stiffen them up for the track and then back them off so you don't lose fillings on the street. Good Luck
  19. Those settings are fine. A nice benign street alignment that will allow you to get the best mileage out of your tires, no problem.
  20. Post the actual values on the alignment sheet and I can tell you if it is worth taking your car back. If you can scan the sheet and post that here it would be even better.
  21. This page explains how to get the mirror out of the enclosure. Hopefully then you'll be able to see how the mechanism is mounted. http://www.toolworks.com/bilofsky/boxster/mirrors.html Good Luck
  22. The best tire I have found that meets the "grip like glue in wet and dry conditions" is the Michelin Pilot Sport PS2. Very expensive and they don't last long, but boy do they work well! http://www.tirerack.com/tires/Sizes.jsp?ma...Pilot+Sport+PS2 I had a set on my M3 at the track in these conditions and everyone who got in the car was shocked at how much grip I had in my totally stock car. Just don't try driving on actual snow pack. Then they act like normal summer tires. ie, absolutely no grip!!!
  23. If you can get the old sensors out in one piece, you can reuse them. The only caution I have for you is that the plastic material they are made of can get very brittle with the heat they have to endure and they may fall apart as you pry them out of the old pad. IF they do fall apart, don't fret. Just tie-wrap them up out of the way on the strut somewhere (that way the brake warning light on the dash will stay off), finish our brake job and replace them at a later date at your convenience. Check out Trygve Isaacson's excellent Boxster brake pages: http://www.bombaydigital.com/boxster/projects/brakes/intro/ If you want to skip the initial brake tutorial and go straight to the meat of changing them, click here: http://www.bombaydigital.com/boxster/proje.../change_rotors/ This is a great writeup that will give you all the info you need to confidently tackle this job by yourself. Once you have finished, you'll wonder why you ever paid someone to do it for you.
  24. I'll ask my wife, hehehe. Or maybe it's THE magnet??? :lol: DO NOT REMOVE THAT MODULE... The black helicopters will show up seconds after you do! :P
