artster
Everything posted by artster
  1. I had a similar chirp/squeak that I heard only when engaging the clutch but it was very subtle - and totally gone after a clutch and flywheel replacement. Also check the torque on your spark plugs - you can get a chirp from a loose plug -Art
  2. Roof strips pop right out - there are plastic clips (~4) under each strip that grip on threaded studs protruding from the channel under the strip. Replacement clips are cheap - plan on replacing them for reassembly. Rubber is screwed on with each screw cleverly tucked under the folds of rubber. Some are real tough to find. Consider leaving the rubber in place and tape it. You can loosen it to better mask for painting.
  3. There is a TSB (number 2469) on the P2096/2098 codes that may apply if your 996 is 2002+
  4. Resurrecting this thread - many thanks for the original post - a great write-up. I just finished refurbishing mine. Fortunately for me there were no broken screws upon disassembly. Also, I went a slightly different route - I had the center sections powdercoated in black, and polished the outer rim. The tires will be mounted tomorrow: Pics before: There was a bit of corrosion on the rim: After polishing: The final product:
  5. I installed the Dension Gateway 500 in my '03 (CDR-23 MOST system) with an iPod. It is not a perfect solution, because the CDR-23 does not display any track information, but I mounted the iPod on a mount next to the dash, and it works fine. The Dension unit plugs into the MOST fiber loop, pretending to be a cd changer - the quality of the sound is superb (well, as good as you can get with the factory setup). Installation was easy, but it did require a trip to the dealer to "enable" the cd changer. The downside is that it is not cheap - I bought mine from bumperplugs. Good luck - Art
  6. The illumination should be on the harness going into the deck. You can use a multi-meter. The illumination wire should test ground when the light switch is off, and 11.8-13V when the light switch is on. Now, this is also true with the dimmer, but the difference is, the dimmer will change voltage if you brighten or darken your interior lights (when switched on), it will range from about 4V-12.8V. Hope this helps. FYI. Dont connect the illumination from the deck to the dimmer, this can damage "some" Decks. According to the pinout diagram (see this post), there is an "illumination input" at terminal A6, but my recollection is that there was no wire connected there. The CDR-23 does vary illumination level with the dash adjustment - but I don't know how it does it... Perhaps the CAN bus? That doesn't really answer your question - but perhaps you can just tap into a dash light line to get the illumination input you need for your Becker unit. The easiest place to tap into that, in my opinion, is the ash tray illumination in the center console. Also, best access to switched 12V is the phone interface connector behind the dash. Good luck - and please post your solution should you find it. - Art
  7. I got mine here: www.xenonmods.com I refreshed the finish on my calipers but didn't need the decals. I cleaned the calipers and lightly sanded with 800-grit sandpaper, feathering the edges where the clearcoat had peeled off, and even more lightly over the PORSCHE lettering. I sprayed the calipers with a clear engine enamel (duplicolor, I think). They look nearly as good as new. - Art
  8. I have the stock 986S dash cluster - no oil pressure or voltage. This has no impact on the warning lights in the cluster. My alternative was to go with the 996 cluster conversion, which has been covered here in a number of posts. The iPod setup is a panasert pedestal that I picked up a number of years ago mounted with the holder that comes with the Dension interface. It is pretty solid, and easily removed for security. It also works as a "hat holder" to cover things up when parked. B) - Art
  9. I installed a gauge panel in place of the cd storage tray. I purchased the panel from 9xauto.com and the gauges from eGauges.com. I got a voltmeter and an oil pressure gauge - and purchased the 996 oil pressure sending unit from suncoast (which operates roughly in the 10-180 ohm range). I painted the aluminum gauge panel with RustOleum satin black, which is pretty close to the dash color, and tapped into the wiring for the phone connection behind the dash. I pulled the center console to run the wire into the engine compartment, drilling a hole near the sending unit, using a wire grommet that I got from radio shack. While the center console was out, I tapped into the dash light circuit at the ash tray bulb. After wiring everything up, the panel literally snaps solidly into place. I went for the VDO vision series gauges which come by default with a threaded collar (spin-lock) to secure them to the dash - but because of the clearance in the dash opening, the spin-lock mount doesn't fit, and you have to order the side-mount (see pics). - Art
  10. The head unit on an '03 with MOST is likely the CDR-23. There is no aux input. I recently installed the Dension Gateway 500 unit with an iPod and it works great (03 986S). The Dension unit taps into the fiber optic loop and mimics the function of a cd changer. It's not perfect, as the CDR-23 doesn't display anything but "TRACK 1" so you can't just stuff the iPod in the glove box and forget about it. I mounted it next to the dash. It's pricey (about $500), but the alternative was a complete replacement of the head unit, amp, and probably speakers... - Art
  11. I just replaced my clutch on my '03 986S - my mechanic also told me it was "heavy" - but to prove the point, he had me sit in a 996 that was in the shop with a brand new clutch. The difference was amazing, but at the time, I passed, since I wasn't overly concerned with a heavy clutch, and decided to wait until the clutch started to show signs of slipping (I was at 65k, driven by me for the most recent 20k). Within two weeks, the clutch was slipping, and I had it replaced.
  12. Looks great! My calipers look like your "before" picture - this is on my list of things to do. Thanks for the pointers
  13. Yes - 03 introduced a redesign.
  14. They're the same - I replaced all four of mine (03 986S) with Bosch 15738 sensors. 04 should be the same - Art
  15. I measure ~19 ohms on the variable side of the sensor from my '99 when there is no pressure. If you use the factory sensor with a non-factory gauge, you'll want to use compressed air with an independent gauge to make sure the sensor and gauge play together. I've been thinking of doing the same on my boxster - but using the VDO sender screwed into the un-used oil pressure tap on the other head. Does anyone know the thread size of the 996 sender? VDO sending units come in M10 M12 M14 or M16 thread sizes - Art
  16. The seat belt chime is a very simple circuit - with the seat belt unbuckled, power is applied (when the ignition is on) to the idiot light and the seat belt chime. Insert the seat belt in the buckle, and the circuit is opened - power interrupted, and no light or chime. This is a separate circuit from the airbag (which has it's own switch in the seat belt buckle to determine if the belt is buckled or not). You have an open circuit. Chances are the connectors, or the seat belt buckle are the problem. Under the driver's seat, there is a bunch of wires going from the floor to the seat. In that bundle, there is a brown wire with a red stripe. Follow that to the connector at the seat, and see what it looks like. You may have to remove the seat to get access - but don't disconnect anything unless you have the durametric tool to reset your airbag light. On my 986S, I actually created the condition you describe on purpose - I snipped that brown/red wire, and taped off the ends. No seat belt light, and no annoying chime. That's the way I like it... - Art
  17. I believe this means that there has been one incident at 198 hours when the engine was spinning between 8400 and 9500 rpm. This can happen with a missed shift - say you're accelerating to near redline in 4th, and hit 3rd instead of 5th. Clutch comes out and wham... The engine controls shut off fuel flow, and will not fire the spark once you hit range 1, but the momentum of the car can still spin the engine faster. You can really only estimate when this happened (if you did it, you'd remember, I'm sure). 198/287=.689; if you have been consistently driving your car about the same amount of time and speed per month, you can estimate this happened 68.9% of your current odometer reading - check your service records to try to pin it to a date. Can't comment on the status of your warranty - you'd have to check with the dealer.
  18. That rules out a bad splice. They could be the wrong type. If you still have your old ones, and an ohmmeter, measure the resistance of the heating circuit - across the two white wires (though yours may be different), and then unplug your new ones, and measure them.
  19. Can you provide a bit more info - year/model, and describe the O2 sensor (direct fit / universal)? They might have sent you the wrong sensors, and you may want to double-check your connections (particularly, if the sensors are universal with a spliced connector).
  20. If your radio has an aux input, all you need is something like this: http://www.installer.com/item/display_item.php?it=aip-rca wire the red lead to switched 12V, black to ground, (tap off the cigarette lighter from behind the dash?) and the rca cables to the aux input (I don't know what form the aux input is - you may need to convert the RCA cable to whatever form that is). To complete the installation, you may want a cradle to support the ipod so that you can control it while driving (though drive carefully!) A third party installer could set you up with this easily. - Art
  21. UPDATE There is a TSB on this error code that only applies to certain Boxster S models (and probably some 996's) I brought the car to my local Porsche dealer (who didn't know about the TSB until I pointed it out to them), they reprogrammed the DME, and I'm all set. My Contributing Membership access to the TSBs has paid for itself again... :) -Art
  22. It's an external torx socket - I recently picked up this for about 20 bucks (had it in a couple days): http://www.sjdiscounttools.com/lis26280.html I figured it's a set that might come in handy with this car. -Art
  23. That could be it - I recently fixed a leaking oil filter housing that was working its way down the wire to one of the sensors. Thanks! Art
  24. 2003 Boxster S 6-speed with 46k, CEL light came on. Plugged in the Durametric, which gives me: P2098 Porsche fault code 22 - Oxygen sensor ageing; Delay bank 2 P2096 Porsche fault code 16 - Oxygen sensor ageing; Delay bank 1 So here I go with the questions - is it common for both O2 sensors to go at the same time? Aren't there four O2 sensors, and is this telling me all four are shot? I'll crawl under it and reset the connectors, visually check things out, and reset the trouble codes. If the CEL trips again, I'll replace the sensors. - Art
