judgejon
Everything posted by judgejon
  1. On the other hand, a 44lb bag of stove pellets in the front drop-in compartment of my 2003 C4$ was a noticeable cornering improvement on curvy mountain roads. I discovered this while driving home one day with a new box of printer paper in front. Tire wear was not affected at all. Nor was acceleration or speed. Note: this was in a C4$. I had installed a shock tower tie-brace in my 911SC that helped cornering. Never needed that in the C4$. All that being said, if you are not auto-crossing or doing much driving “full ahead,” why bother?
  2. As Loren would say, the search engine is your friend. The wire fix is simple, but getting to it is a royal pain. It’s down in there below the battery tray. Good luck.
  3. Which Carrera is this? Mine was a 2003 C4$.
  4. Yes, no issue there.
  5. Another thought: my very good Inde (now retired) advised against “short shifter.” I had the hot-rod issue of shifting too fast from 2nd up into 3rd, I think from just popping the clutch too quickly. Only from standing start, like drag race. Human error. Never an issue on local twisty mountain roads. But I’d still wonder about the cable connections as mention in the last post. This is a puzzle. Continued good luck.
  6. Totally agree re looks of 996. Even the headlights have grown on me. Loved driving the car every day I had it. Changed only due to my physical issues.
  7. Loren, I still enjoy your bag of tricks. Cheerio,
  8. Hey, old friend, sorry to read about your issue. wish I could help you out, but no joy here. Good luck, good thoughts.
  9. I guess never had the issue as I never let the maintenance get behind. did you just purchase the car? model? Year? good luck.
  10. Mine never was. 2003C4$. you should post up year and model. cheers,
  11. If it’s not making rattling around sounds it’s probably ok until it does. But if you’re in a location that does smog testing consider just waiting to do it until you really have to. just sayin. Good luck
  12. Johnny, I forgot to ask, what car/cars, are you driving/racing/working on? As a former owner, I can tell you that I still keep a replaced, expensive, oil sump pump, and two older sealed timing chain tensioners from my 911sc on my workbench in the garage. Not driving a Porsche right now, but like to keep my fingers in the pie, so to speak. Sold that one at about 325k miles. Sold my C4$ at 16 years old. My issue was getting an old body in and out of the car. Still enjoy Loren, Jeff, and other folks on Renntech. Cheers, j
  13. Agreed here as well. If I still owned my C4$ that’s just what I would do.
  14. Doesn’t that approach risk catastrophic engine failure? Would it be better to just replace engine?
  15. Yes, and no telling what else is screwed up. Sorry that you’re in this predicament. No good answers.
  16. If you are concerned re IMS issue, get the LN solution installed and forget about it. Good luck..,
  17. Mark, there you go...one of the pros has stepped up to the plate. As suspected, your next stop to fix this issue is your local friendly stealership. Again, good luck.
  18. You might need help from the stealership on this one. Might take a piwis to reprogram everything. Best I can say. Others here will likely jump in. Good luck.
  19. Change battery in key fob. Might be an issue, cheap enough to try.
  20. Never asked, is your car a 6-speed or automatic? Might make a little diff re ability to drive. I obsessed over under slightest noise from seat motors, fearing that if seat got stuck I might not be able to push on clutch.
  21. I recall loosening the bolts to be able to lift the seat to get to that screw drive and lube it. Then just crawled in from the rear floor to do as taking out the bolts was such a pita. But if the seat doesn’t go forward and back I think your done. I recall the seat motors under there. But if the seat doesn’t move at all it’s likely a trip to the stealership. Problem is how to drive the car. Could you possibly, just to drive to the shop, fasten a “booster” seat using the seatbelts. Right, like a baby booster seat. Temporary only of course.
  22. Yep, ignorance is bliss. my recollection is you cannot manually adjust the powered seats. I remember the procedure for lubing the forward/back screw-like drive, but don’t recall ever reading about any manual adjustment. good luck.
