judgejon
judgejon last won the day on June 18 2022
judgejon had the most liked content!
About judgejon
Contact Methods
  • ICQ
  • Yahoo
    judgejon@yahoo.com
    Mendonesia
    2019 X3 M40i
    2018 X5
    2003 C4$ (sold)
    1979 911SC (sold)
2,542 profile views
judgejon's Achievements
  1. Never mind, I’ve got it… you’re going to be selling the car and need a smog certificate. I did this twice. Good luck.
  2. I had this problem years ago. Check seatbelt buckles. Check for info via search engine. Hi Loren and Jeff. I’m still driving M40i. Maybe back to Porsche someday. Cheers.
  3. Great. Good luck. I truly enjoyed my C4$ everyday I owned it. Cheers,
  4. Your last paragraph is a real puzzle. Looks like a sleeve broke off of something. Wow. No noise? Must have happened after last shop work was done. Good luck.
  5. What you’re doing isn’t going to solve the fueling issue, imho. Good luck
  6. No clue. keep striving. Good luck
  7. This happened to me with my 2003 996 C4$. There is a sensor on top of the fuel tank that I believe relates to fuel pressure in the tank. If the sensor goes bad the tank filler valve in the fuel line won’t open and you can’t fill using a gas pump. You can still pour gas in slowly by using a funnel. The sensor is a bear to get to. The battery tray has to come out. My issue was that a mouse had nested and chewed the sensor wire apart. Really. Check the search engine on the forum. Others have had the same issue. It takes some time to get to the sensor wire and put everything back together. Fixing the wire itself takes about 2 minutes. Good luck.
  8. Loren , I think you’re right. I think I remember dealing with those on my 996. Cheerio,
  9. Main bearing? good luck…
  10. I worried about stuff like this this for years. And kept a clothes hanger piece in door pocket to open gas filler flap if necessary. can you reach the latch from under the front of the car? Good luck
  11. My memory is that the airbag light can come on if seatbelt buckle connection is loose or faulty. Try opening and closing seat belt a few times. Good luck. Get fault code to Loren. Cheers,
  12. Michelin PS2, or latest Porsche approved version. Best I used. Gosh, I still miss the “tire wars” on the forum years and years ago.
  13. Leak under pressure at a radiator hose connection? But no coolant leaks… ? Good luck.
