1101mv
Everything posted by 1101mv
  1. I have a 996 wing lying around from an aftermarket install, I can check for you. Can you be more specific - was it the plug inside the wing or the plug that connects everything (fan included) to the car? Its the plug that plugs into the brake light on the wing.. Let me know thanks.
  2. Murphy told me if you don't insulate them from each other they will short out! Can i buy just the plug and if so whats the part number?
  3. Just got the smoked led brake light from carnewal, however had to swap out the wires for the light on the wing. While doing doing so I broke the plug, do I have to buy a new wiring harness or can I just install the lose wirings with out the fear of shorting somthing out.
  4. My passenger door wont open either from the inside nor the outside. However when I lift the door handle the window does come down a inch or so. HELP :(
  5. Will the H&R sway bars make a big difference? :drive:
  6. Well, I taught it would be cheaper to just do it while the PSS9s get installed.
  7. I am installing the pss9s kit on MY99 C4. Shall I also change out the sway bars? Was looking at the H&R ones. What do you guys think?
  8. I had to adjust the spring and put some lube and its perfect now. Thanks again Loren. Here is a pic of what I was talking about.
  9. Thanks Loren. I bought a rivet gun and it worked out well. However having trouble putting back in the spring. I am not sure if I installed it coerect. It makes a clicking noise when I raise the lid.
  10. How do I rivet the hinge using the supplied pop rivets? Do I need a special tool to pop rivet the hinge?
  11. How do I remove the rear center console lid? How do I put it back on? I am exchanging the console for a silver one. Help. Thanks
  12. Is the relay something I could buy? Does renntech have install directions?
  13. Loren do I have to buy the relay and wiring or does it come with the windshield?
  14. Loren then why does Porsche offer two type of windshields, one with a rain sensor and one without? Since I have to put in a new windshield should get the rain sensor one?
  15. When my body shop guy went to order the windshield why did they ask if I have the rain sensor option? Does the sensor come built in to the windshield?
  16. I have a 99 C4 that needs a new windshield. I don't have a rain sensor currently, can I put in the windshield with the built in rain sensor and will it work fine and how much of a mod is it if any?
  17. I have all ready done the turbo face lift on my99 c4 and wounder if I can fit the rear turbo bumper on. What parts do Ii need?
  18. I am about to change out my air filter on MY99 C4. Should I put in a BMC, K&N or just stick to a stock one?
  19. I have a 1999 C4 996 with 56,000 miles on it. A new engien is being put in under warrenty. Should I also replace the clutch and fly wheel while at it?
  20. Will the siver plug fit my99 C4? Thanks Loren
  21. Can you buy just the silver airbag plug that is located on the doors? If so what is the part number?
  22. Do I have to remove the door panel and the window to replace? Also whats the part number on the rubber trim. Thank you.
  23. How do I remove and replace the rubber trim on the out side of the door windows?
  24. Yes the overlay metal trims are glued on. :help:
