jeffreyedgar
About jeffreyedgar
  • Birthday 01/09/1949
Contact Methods
  • MSN
    jeffreyedgar@live.com
  • ICQ
    jeffreyedgar
  • Interests
    driver coach, travel to France, wine, Porsches
    Roseville, CA
    2006 Porsche Cayman S
    1995 Porsche 968
    2000 Boxster Tiptronic
    1988 944 Turbo
    1984 944
    1970 914
jeffreyedgar's Achievements
  1. The email address for Car Audio is hotrod930@msn.com
  2. Try Car Audio Innovations, www.cal-store.com, or some other advertiser in Panorama or Excellence. I used Car Audio for an installation in my 968. The owner has or had a 930. You may get the guidance you are seeking.
  3. If you do not get this fixed, then there will be more problems to follow such as an oxygen sensor, catalytic converter, tune-up, etc. Take it in for service right away.
  4. The code will certainly help narrow it down. If your code is "Ignition Circuit Driver" (code 21 IIRC) it will exhibit the exact symptoms that you are describing (i.e., the light goes off when you reset it, but goes back on a few seconds later). That fault can sometimes be resolved by repairing or replacing the "clockspring assembly" (ring under the steering wheel). Regards, Maurice.
  5. I have a 2000 Boxster with the airbag light illuminated. I have reset the fault code but the light stays off only momentarily. It appears that there may be a control unit issue. Is it likely to be a control unit issue and is it possible for me to replace it easily?
  6. lives in Roseville, CA.
  7. I have a 2000 Boxster with the airbag light illuminated. The fault code is 21. There is reference to ignition device. Is this a fix that I can perform?
