Dale Zelinsky
Everything posted by Dale Zelinsky
  1. 996 111 121 05 Thanks! I am pretty sure it is a muffler but is it the newer 03+ style?
  2. Why bother removing the cap on the new one?
  3. Do a search.... You have to move or splice the remote turn on lead for the amp. (I forgot the pin numbers) Very easy to do.
  4. Dale Zelinsky
    A/C is out
    These Microsoft jokes are still, after all this time, quite amusing.
  5. Thanks for the replies... The shipping doesn't seem to be too hard to find... I just can't find anyone to crate it..... :(
  6. I bought a hardtop, but it is 900 miles away. I thought about doing a roadtrip, but once you factor in gas alone I am already at $200 For twice that should I be able to get it crated and trucked in? (Virginia to Florida) thanks
  7. "The CDR-23 does not have AUX input.." You have to use an FM Modulator.
  8. AFAIK you have to use a PST2 and set the radio from CDR23, etc to None. I have heard that if you do not, the Alarm will not arm. (I have not verified this)
  9. No programming as in the code for the unit didn't need to be added to your cluster to work?/ Weird.
  10. I spent 4 hours installed it and removed the next day. The map data was crappy for my area (Orlando) and I found the menus to be non-intuitive. Maybe I am just picky, but I thought I would share.
  11. Looks great! How much to do mine? :) (same color)
  12. Does any one have the wiring diagram for Cayenne speedometer cluster? thanks
  13. I am installing a new Nav system tomorrow, and I need to connect the Reverse signal and Parking brake switch to the unit for safety reason. Where is the best easiest place to tap into those connections? Thanks
  14. What is the point of the Reverse signal?
  15. Is there any difference between the Porsche Traffic Pro and the Harman version?
  16. Typically one spot higher than normal? thanks
  17. supposedly LAporsche.com has a solution for adding the PCM in not PCM cars. Has anyone checked this out?
  18. According to my dealer, Part number 000-044-500-10 is 17mm spacers with all mounting hardware. Jeff, can you verify this?
  19. Here's what I have... Sorry for the crappy picture...
  20. What size wheel spacer would work well on a 2002 986S with 18's? Where is a good place to get them? thanks
  21. Can you give me a link to what a Boxster Red surround looks like. The surround I currently have for my 996 gauges is some sort of faded red. I am not sure if that would be Boxster Red or not.
  22. Will do... What do these bad boys cost from the dealer anyway?
