JP-"S"
Everything posted by JP-"S"
  1. no the noise was coming from the springs getting beat up. now there are only four in the states two in Atlanta and two in Texas
  2. Number 6. are they about 1/2"in diameter
  3. exposed the rear break after removing rotor. The large spring was a mangaled. Now I need to find schematic with a part number??
  4. I will ry to remove spacers tommarow
  5. no play in the wheel> I just torqued them again. If the bolts are to long did I hurt my car? I ordered them from Ernies alloys on suggestion on the PPBB W/bolts.
  6. :help: My car started to make a strange CLANKING sound after installing the wheel spacers. I did not have the washers on the new bolts since they were recessed. anywho It started to make that clanking sound and I do not know what is wrong? Any help please? Some of you may remember my horror story after I installed Eibach springs on. I had it aligned by a reputable shop. Apparently they did not do a good job for my rear tires were gone in 200 miles. I just got it re-aligned today. I WANT TO DRIVE!! HELP ANY ANSWERS
  7. Thank you again for the help. Question When I put the springs on the rear the bolt with that witch you set the alignment by came out easily. The other side I had to beat out and back in, This just so happens to be the side I am having a issue with. I just mentioned that to the mechanic doing the alignment. He said somthing may be wrong with the bushing or something is bent.
  8. Lowered 1" w/Eibch springs now the mech. can not get past neg. 2 1/2 degree. Hence chewing alot of tire. :soapbox:
  9. Thank you for the help. Like I said I have no clue why but after removing both wheels it stoped.
  10. Took both wheels of and now the noise is gone. :lightbulb: :thumbup:
  11. I thank you for the help. It sound as if it is coming from the front drivers side. Saying that currently i have it in the air with the wheel off to check that out. Like I said turning left only turn right =nothing. I have also just checked the PPBB archives and there is a post about a recall on these parts. also someone said the dust shield. It is making a grrr type sound though that cant be good. Once again thanks for the help.
  12. No wobble can it still be the bearing? The sound it makes is a grinding.
  13. :cursing: Took a drive this morning to find my car is making a grinding sound. It only does this when making left hand turns. I am guessing wheel bearing. Please does anyone have any feedback? :help:
