lous320
    New York
    Mercedes clk 320
  • Future cars
    2005 porsche 997
1,656 profile views
lous320's Achievements
  1. I had my 997 .automatic door-lock programming set using the PIWIS of my dealer. I have had no problems or warning messages.
  2. I installed a Roady 2 Xm radio. The roady 2 sends audio to a unused fm station. no wires to hook up to radio. very easy to install. :eek:
  3. I am installing the same system. How do you remove trim where mike is placed. :help:
  4. The PCM Lists for around 2,000.00. If you remove pcm you will not have navagation. Also PCM controls Sport Chrono Package. the PCM controls Porsche computer. The PCM is wired with MOST Bus System. You can not add a after market radio to this system you would have to rewire the whole audio system. :eek:
  5. Their is a factory recall on the 997.(Air Bag Module rebolting. Air bag Module might come loose. :eek:
  6. I turned the 4 Hex locks on the pcm. The PCM will not slide out. are their any screws that :help: have to be removed to slide out the PCM. please help.
  7. I am installing a phone kit. I need he steps on removing PCM radio from center instument panel :help:
  8. You can get these on E-bay.com just search porsche 997. their are many for sale brand n :drive: ew from porsche fora lot less.
  9. I need the procedure on removing PCM Radio on 2005 997 911. I am installing a phone kit :drive:
  10. I have a chance to buy a set of used xenon Head lights for the 997. I have a 997 with no xenon lights, I would like to know If I buy these lights do you just have to plug these in with no modifications.Please Let me Know Louis :drive:
  11. I have a 2005 997 I have the same problem when sun roof is fully opened. I get a deafening sound. When the sunroof is half opened no problem. :drive:
  12. I am Installing A Motorola Blue tooth car kit. I would like to know the location and wire color of the Audio Mute wire for the PCM. and if I could run audio thru car speakers. :help:
  13. I am interested in getting the porsche cell solution for my 2005 997. I would like to know if it will work with a Motorola V710 Phone. and how do you answer a call with this system. :drive:
