milleplod
Everything posted by milleplod
  1. Thanks for the tips! :) After that, its tyres X 4 and a full realignment. Pete
  2. I was going to use these - Powerflex A friend has a workshop with a press, so that'll be the way to go I think. Pete
  3. Has anyone re-bushed their front suspension rather than buying complete new arms (or had it done for them)? Any problems getting the old bushes out? Pete
  4. I did some more digging around. Its definitely not Pentosin....I dipped some out of the reservoir and compared it to the stuff that's leaking - nowhere near green enough or fluorescent enough!! I'm told the aircon system would have the fluoro green dye in it to aid leak-finding, so, bearing in mind I've got the orange/red coolant, I'm going for refrigerant! I'm going to have to take it into the workshop though, as I've no facilities for doing it myself, unfortunately. Thanks for the advice so far guys! :thumbup: Pete
  5. Now I am confused!! Does one of the 2 parallel pipes under the door carry PAS fluid?? :unsure: Pete
  6. Washer fluid is blue! Coolant definitely the orangey-red stuff. Pete
  7. Will try to get one done in the morning! I bow to Loren's way superior knowledge, but if it is coolant, there's something weird going on!! Pete
  8. OK, I'm going for a refrigerant leak (not that I know much!)....my coolant is definitely the red variety (at least, it is in the header tank!) and this luminous green stuff seeping out is stone cold (with a stinking hot engine) and slightly tacky between the fingers. Would you agree, Loren? If so, is the refrigerant pipe difficult to replace? Pete
  9. Is it a major job replacing the pipe? DIY possibly? Pete
  10. Hi Loren. Just spoken to my wife....she's out in the car (only spotted the liquid on the floor after she'd gone!). She's looked under the car and says the leak's coming from a pipe that runs more or less the full length of the car, at a point roughly under the driver's (r/hand drive) door handle, and seems to be where a bracket's supporting the pipe. So.....I'm thinking coolant pipe, possibly worn through by the bracket? I was sure the coolant was red....presumably not! Pete
  11. The wife's '99 Cabrio has sprung a leak somewhere! Got up this morning and noticed a small puddle under the driver's door area (right hand drive car!), and its bright green! The coolant is the red stuff. Is the leak likely to be from the aircon system? :huh: Pete
  12. Speedo indicates 60mph, you will actually be doing 62.7 mph Stock revs per mile = 815 285/35 reavs = 780 Stock Sidewall = 3.4inches 285/35 sidewall = 3.9inches Circumfrence stock = 77.7 inches Circumference 285/35 = 81.2 inches Well you might notice less handling higher sidewall and probably less footprint, and better make sure they 35's dont rub anywhere. Porsche tunes it's suspensions to the use specific tire sizes. Personally i would not do it! Thanks for the reply....the tech info's useful! I'm with you on the 'don't do it'! A moment of madness, caused by the thought of saving a few pounds, led me into temptation....but its gone now! :rolleyes: Pete
  13. Morning all. The wife's Cabrio is currently running 285 30 18 rears. Just been offered a pair of 35 profiles at a bargain price. Other than making the speedo under-read slightly, anyone know of any problems using these? Pete
  14. Thanks for the reply. Someone over on 911uk directed me to a specialist who can re-bush the whole front for us - in years gone by, I would definitely have had a go myself, but these days....well, I'd rather pay someone! The front of the car feels quite vague and 'floaty' at the moment, so I'm hoping re-bushing will sharpen it up a lot, although I'm a bit wary about mention of a harder ride....its very hard now!! Pete
  15. Morning all. The wife's Cabrio has started making the well-documented groaning noise from the front suspension. Its booked in in a couple of weeks for new discs/pads, so we'll get this sorted at the same time. I was always under the impression that this would mean new control arms as bushes weren't available seperately. Then I found this place http://www.powerflex.co.uk/products/911+(996)-525/1.html. Has anyone re-bushed the front, rather than purchased complete new parts? Pete
  16. Well, I had a bit of luck! :) First, I did the reset on the upper/lower window stop positions, then I had a look at the seal itself, in the area of the top of the windscreen pillar. I didn't do anything very precise, just fiddled about with the 'floppy' bit of the seal at the top, to see if it could perhaps have become mis-positioned. The good old English weather obligingly gave me the ideal opportunity to test my 'adjustments' that very afternoon, and guess what?! The leak's gone! :D Not sure if it was the reset or the seal that sorted it, but its sorted! :thumbup: Pete
  17. Hi! I was hoping for some feedback to convince me I was about to spend around £150 on the correct part!!! Ah well, its only money, and I can't see what else could be at fault really. I'll order the part tomorrow and let you know how I get on. :rolleyes: Pete Pete: Have you checked to make sure that it is not just an adjustment to the door glass that is needed? Have you compared the height and forward to aft position of the door glass on the driver's side with that of the passenger's side door glass to see if there is any measurable difference? If there is a difference, you may be able to adjust the door glass that is leaking to match the positioning of the "good" side. You can actually adjust the inboard/outboard position of the top edge of the door glass without removing the door panel, as well as raise or lower the final closed position of either (or both) the forward top corner or rearmost top corner of the window. If you think this might be a solution to your problem, post here and I will look for a write-up I had done on a similar issue a while back. Regards, Maurice. Hi Maurice. I never thought of that as a possible answer! Once it stops lashing with rain, I'll go and take a look and get back to you. Many thanks. :) Pete
  18. Hi! I was hoping for some feedback to convince me I was about to spend around £150 on the correct part!!! Ah well, its only money, and I can't see what else could be at fault really. I'll order the part tomorrow and let you know how I get on. :rolleyes: Pete
  19. Evening all. Whilst parked up in the wife's Cabrio the other week, in pouring rain (top up!! :rolleyes: ) I noticed a small amount of water coming in from the top of the passenger door glass.....it was dripping off the windscreen pillar. As we intended to put the hardtop on fairly soon, I didn't do anything remedial in case it was just a soft-top issue. Anyway, the hardtop's on now. Today, parked in heavy rain, the drip's there again! :angry: I'm therefore assuming that its nothing to do with the seal on the softtop, but that its the door aperture seal, which runs up to the top of the windscreen pillar. I can't see any splits in the seal. I've found the part number for it, but am wondering if anyone's fitted a new one themselves. Anything awkward about it at all? Can anyone direct me to the workshop manual instructions for carrying out the job? Thanks in anticipation! Pete
  20. Good question....and one I've been meaning to ask myself! Ours is blue, and despite cleaning it with 'highly recommended' products, it still has marks that I'm convinced can only be eradicated by a re-colour to black. I'm pretty sure though that fold-marks and creases will still be visible - I see plenty of cars with black tops that have these...even quite young ones. Pete
  21. Thanks for that! Valve now closed....mind at rest! :rolleyes: Pete
  22. Morning all. I've just replaced the header tank on the wife's Cabrio. What a PIG of a job....but a great feeling of satisfaction now its done! Thanks by the way to the people who put the info on here....really helpful. Quick question regarding the bleeder valve. I've been out a couple of times with it open....the engine's still hot....the valve won't close. Am I right in thinking that's because the coolant is still stinking hot? Will it close once everything's cool....or is there something wrong with it?! Pete
  23. Hi Loren. I found this that I've attached..... I think its just reiterating the 'microswitch and rocker switch' instructions. Thanks. Pete
  24. Afternoon all. The rear window seals ('gaskets' in Porsche-speak) on the wife's Cabrio are looking tatty (the ones that are fixed to the windows' rear edges), so I ordered a new pair - very reasonably priced for Porsche bits at about £9 a side....in fact, the recommended Loctite 480 adhesive is twice the price! :o The instructions in the manual seem easy enough to follow, but do say to refer to 'service no. 61 71 19', which looks like a sheet number. Problem is, I can't find it anywhere in the manual I downloaded! Has anyone got this? I can't see that its going to be anything major....but would like to put my mind at rest! Has anyone done this job themselves, by the way? Pete
  25. Thanks for that....will do! :)
