efedor
efedor last won the day on September 12 2018
efedor had the most liked content!
    el paso tx
    2004 Boxster
efedor's Achievements
  1. Brad is that a picture of your Porsche? I think I saw It in barstow, Except the scoop was a perfect match to the custom car paint.
  2. No problem linking things up, NO it didn't include the linkage kit. I bought it from ebay and it came with 2 seatbelt schnell wraps. Just buy it and ENJOY!
  3. I purchased the schnell short shifter and it has worked well for me. The instructions are simple and easy to use. They do not come with a small tube of grease which I recommend you get. Perfect fit and makes a big difference... makes you ask yourself "How come I didn't buy one sooner".
  4. I would like to hard wire my tom tom but I don't know where to draw the power from. I know most people get it from the fuse box but Im not sure which fuse to attach the positive cable to,an where to plug the negative? Any suggestions would be greatly appreciated thank you in advance.
  5. Thanks for the reply Glyn, that's the kind of answer I was expecting not the slap on the hand don't do it approach stated by others. I never force my gears or grind the box, It would be stupid of me to do on a fine german car like ours. Since I don't race,redline or peel-off or do any crazy thing on my porsche, Im sure It will last a long time. Thanks
  6. Got it guys, Thanks
  7. As I have a heineken, I apologize for my UPPER CAPS use. Like Mt everest, it's there so climb it, I too feel that way. If I can shift it then I will do so. Am I wrong? ohh well only my wallet will tell. Sorry for the short temper, call it PDS. GOD LOVE AMERICA.
  8. HEY, EVERYONE IS TREATING ME LIKE IM A YOUNG PUNK, IM MEARLY ASKING IF IT'S OK TO SHIFT CLUTHLESS ON A BOXSTER, NOT PERMISSION TO DO SO. IM DOING IT BECAUSE THE CAR ALLOWS ME TO,NOT BECAUSE IM SOME IDIOT THAT CAN DO IT.
  9. I don't speed shift, I shift when the tranny allows me to and thats usually at about 2.5k to 3.5 so it's relatively slow. I do it because I get tired of shifting!. I do not downshift without a clutch.
  10. I've owned my boxster for 4 years now and I usually shift without the clutch(except first and down shifting). Will there be problems in the future or am I ok since I don't grind the gears or jolt the car when I shift? Am I the only knuckle head that does this?
  11. YES desnorkled! No I told them not the wash the engine but like an idiot, I forgot to tell them not to trow water into the side vent (intake).
  12. So after I had the guys detail my car it sat around for 6 hrs or so then I tried to start it and it ideled rough and the cel light came on and a few seconds later it ideled normally. So I raned an erand and the car worked fine until this morning when it did it again. Did the guys put water into the exhaust are any sensors damaged? The car runs great without any problem exept at start up. Any help would be apreciated. 2004 2.7 speed yellow 30kmiles. UPdate: I unplugged the battery for and hour then it worked fine,light went a way. This morning the same thing happened again but the cel did not lit up. After 5-10 secs it works fine again.
  13. Ok I opened the front.. no light. I leave front open, then I open the rear and BOTH lights go on! I close the rear.... front turns off! what the...
  14. OK i'll look into it tomorrow. thanks
  15. Is it a bose rear speaker?
