M A $ E
About M A $ E
  • Birthday 09/23/1976
Contact Methods
  • Website URL
    http://
  • ICQ
  • Interests
    Cars, Girls, and Gadgets. what else is there?
    LBC
    04' Porsche 40th anniversary 911 modded
    04' Porsche Cayenne Turbo modded
    03' MB E500 modded
    05' Scion xB (hey, it was free alright)
    00' Kymco people 50
  • Future cars
    997/998 turbo
    998 GT2
    MB E55 or BMW M5
    Ferrari F430
    Future dream cars:
    Carrera GT
    Bentley Continential GT
    Aston Martin Vanquish S
    1964 Ferrari 250GT California Spyder
    Aston Martin DB5
    Eleanor
    1993 Honda DelSol (it all started here)
    1987 Porsche 930 Turbo Slantnose (Dad's)
    1995 Ford Explorer (featured in Truckin's SUV)
    1999 MB ML430 (featured in Truckin's SUV centerfold)
    2000 Nissan Xterra (got us through work)
774 profile views
M A $ E's Achievements
  1. hey Jinijazz, in my opinion, they are still a little yellowish, but def better than the stock ones. you can really notice the difference when you are about 10 feet away form the car. The old ones make your xenons look pretty yellow. with the philips bulbs, not so noticible. let me know if want this extra set to save time and shipping from the UK. $25 shipped to you.
  2. I'm pretty sure they use the same xenon bulb. the city light in question is the same H6W check this link. http://www.6speedonline.com/forums/showthr...t=philips+xenon
  3. jinijazz, you're right. the city light is yellowish. You need to buy the Philips Blue Vision H6W bulbs. they match up really well and reduce the yellowish tint that it casts on your litronics. you can't get them in the US as they come from the Europe. They don't make your headlight look bluish either as they are pretty small. If you're interested, I have a extra pair in the package still. otherwise you'll have to order them from the UK.
  4. welcome! wow, 5AM and 3AM? you sure have some sleep issues... then again, I remember I could't sleep either when I got mine!
  5. no, I was just wondering if you had a clip of how it sounds?
  6. So I gave the dealer a call. fairly basic... 1. remove all pastic trim pieces around the engine bay via 1/4 turn screws (watch out the pop out sometimes), you'll notice the air filter housings on both sides. 2. start with the driver's side and look for the 2 plastic torx screws (T27) on the lids of the housing. 3. Look closely and you'll notice the head of the torx screw is not round. it was a small extension protruding form the circumference of it. 4. look even closer and you'll nitice a black dot debossed from the housing around the head of the torx screw. 5. line those 2 up and give it a pull and the whole pin will come up. 6. undo the 2 metal spring clips and you'll be able to pull the lid completely off. 7. replace the filter and repeat steps for the otherside. 8. However, there is 1 extra step on the passenger side that needs to be taken. you'll notice a vacum tube in the rear bottom of the lid that needs to be removed first. It's a *****, but it does come out. don't forget to out it back in when you are done changing filters. 9. all done. :thumbup:
  7. ah, man. I surely will post a diy one I figured it out. wish me luck! time to make a couple of phone calls...
  8. does anyone know how to install the aftermarket air filters for a cayenne turbo? I see the spring clips on the top but something is holding the rest of the housing on the bottom. I found a DIY here at renntech, but it's for the Cayenne S. The piping on the turbo is different since the S' intake goes directly to the throttle body. I can't seem to be able to get the housing lid to come up and off. Loren, do you have a TSB for replacing stock filters?
  9. Thanks fellas! I'll brave it this weekend and see where it gets me. So the lightweight bumper is a must it sounds like. mudman2, I'll hit you up if I want to trade. thanks for the offer!
  10. Does anyone have a step-by-step procedure to removing the rear apron? My CT came with the facorty option tow hitch and I want to remove it for some weight savings and since I never plan on towing anything with it anyways. thanks in advance!
  11. I recently installed my new aluminum face gauges. During the installation, I didn't rest the floating dash on a towel, so now my full leather dash has these mars in between the instrument cluster and the steering column -- from the mounting points. they are not creases in the leather, they almost like indents in the semi-soft leather dash. does anyone know how to get the leather to rebound back to it's smooth original state? I've tried wiping leather cleaner into it to condition and hopefully soften it up, and I've tried to heat it up with a hair dryer. nada. It seem to rebound a bit itself overnight, but not quite well enough. any suggestions? P.S. if you are going to do this, be extra careful. During the whole install, I not only marred up the dash, a couple of the needles on the gauges didn't work (which I later fixed), and had a very hard time removing the trim from the hazard light switch which I basically had to rip out. The dealer wants $87 to replace that small piece of abs around the hazard switch!
  12. Well I finished the bypass pipes saturday morning and I'm very HAPPY with them!!! They sound great and help the car move a little quicker on the highway. Did I mention they sound great? you can finally hear the V8 and a bit of turbo whine. I def reccommend this mod to any 955TT out there! OK, so I gotten alot of info on this board, so it's time for me to give some back. You can totally install these yourself in a couple of hours, as long as you know what you have ahead of you. 1. with some WD40 on the nuts ;) , you should be easily able to loosen the metal sleeves that join the 2ndry cats to the pipes that lead to the muffler. there are 2 nuts on each sleeve. NO need to remove them, just slide them over to disconnect the 2 pipes. 2. each flange that connects the 2ndry cat to the primary cats, is held by 3 bolts --6 in total. On inspection, you'll notice that 4 of the six (2 on each side) are no- brainers as far as removal. remove them. and move onto the one at the top of the flange on the driver's side. It takes a little bit of work, but with persistence, you'll get it off in no time. 3. The nightmare bolt at the top of the flange on the passenger side: is actually really easy as long as you have the right tools. after hearing back from itzkirb, who suggested that I either remove the wheel (as he did it) or to go through the engine bay, I opted for the latter. I went to Autozone and bought two 24" socket extensions and a U joint extension to connect the two 24" exts (this help give the extention contraption some side-to-side mobility) . My wife then held the extension steady at the engine bay as I went under the car to guide it into the nut. Came back up and easy wrenched it off. VOILA! 4. went back in reverse order (didn't need the extention trick to get the top bolt back on, since without the cats you have more room and the fact that there is steel flex mesh to provide some give), checked for leaks and did a test run! It's def a DIY project. why waste $150 for installation? you could use that money for the BMC filters! GOOD LUCK!
