Gabriel
    2002 Porsche 911 Carrera
Gabriel's Achievements
  1. Don't dealers also sell the connector to plug in to the phone prep? What is the part number?
  2. I find it surprising the variance of opinions on this topic. Most people seem to agree that introducing air is not a good idea, though. But it seems that for at least one person that has worked categorically well. How can that be?
  3. Sorry, I'm afraid I don't follow that. A and B gives me the left and right alignment of the leftmost part of the 9 and the rightmost part of the right 1. In what way does that give me the angle of each number? And then, what about the middle 1? I apologize if I'm missing something... .... After looking deeper into this, it appears these logos come on a sheet of paper when new, so the placement and angle of each number is by definition correct. What I have is the three numbers by themselves, so that makes proper placement much more complicated as I need to stick them one at a time.
  4. Loren, what is the angle for each number?
  5. I have a 2002 996 and the clutch also engages fairly high. I tried removing the boost spring but couldn't get it out. In any case, the technique 1999Porsche911 is recommending sounds a lot better, as it will lower the engagement point which will make removing the spring an unnecessary thing. I am concerned about this technique, though. Why is it no one else recommends this? Doesn't introducing air create a spongy pedal feel? Any other side effects? Doesn't this go contrary to the notion of bleeding the hydraulic system?
