500 Mile Report.
The car is a joy to drive. So much power. Idles very smooth too.
When it rains it pours though. Right after I installed the engine I tested the variocam actuators with Durametric. Both banks worked, however shortly thereafter I couldn't activate bank 1 when I tried it a second time and got a P1531 code. I ohmed out the solenoid and it read near 0. Whereas bank 2 read over 13. So out came the engine again to replace the solenoid. Engine installed a second time and I've put 500 miles on the car since.
Oil consumption seems to be near zilch at this point, wheras before I would have blown through perhaps 1/2 quart at 500 miles.
One outstanding problem though. Bank 1 is accumulating more soot in the tailpipe (signifigantly more) than bank 2. In fact, the right tail pipe is pretty much black with soot (I had cleaned during the rebuild) whereas the left tail pipe is basically clean. This problem was devleoping before the top end rebuild and it doesn't seem to have changed afterwards. Yeah yeah, what does soot matter anyways - if the car runs great who cares, right? But I am concerned that the two banks are developing soot at a different rate.
Cylinders were very smooth when I had the heads off. Could not see or feel any imperfections (of course that doesn't mean they weren't oval, which I did not measure...). But I sorta took a gamble the purple smoke (now gone) was going to be the in heads anyways... (which several valve guides were found to be shot).
So thinking perhaps the soot build up could be worn rings on one or more cylinders in bank 1 since I had just done the top end, must be the other end right? The out of spec valve guides and all the valve seals were replaced during the valve job (not to mention 3 way valve cuts to ensure perfect seating)... so pretty confident where the air would leak out...
I decided to do a leakdown and compression test. Warmed up the car and proceeded to get the results. Much to my surprise...
Leakdown (in each cylinder the air was leaking through the oil filler tube indicating worn rings, not a hint of air from the top or bottom end).
1 = 23%, 2 = 24%, 3 = 24%
4 = 25%, 5 = 25%, 6 = 26%
Not too bad for an engine with 75,000 miles on it. Not that good either, but probably not a reason to tear into it again at this point, looks like the rings have a few more miles in them. At least it shows even wear and the engine still performs well.
Compression
1 = 155, 2 = 154, 3 = 150
4 = 149, 5 = 149, 6 = 149
And when pulling the plugs ALL of bank 1's plugs (cyl 1-3) look identical to this.
Whereas ALL of bank 2's plugs look identical to this.
Pulled the headers and the exhaust side of bank 1's head is all black and sooty after only 500 miles already whereas bank 2's head is relatively clean (albeit not sparkling like it was after the valve job).
So now I am a little stumped, perhaps it is due to a fuel delivery problem?
I thought perhaps the MAF could cause this, but then I should see consistency between both banks. Found a great thread on the subject, however again the problem here is with 1 bank and not both.
http://www.renntech.org/forums/topic/21472-fuel-air-mixture
Perhaps it could be O2 sensors, however they are all brand new (and same problem with the old ones).
When I did the rebuild I had all the injectors sent off, tested, cleaned, and orings/filters replaced. I also cleaned the fuel rails as best I could with compressed air - there were no apparent blockages.
I seem to remember that the design of the fuel rails might have changed with later model year cars. Perhaps this is just how the 1999 model M96-01 runs? A little richer on bank 1 than bank 2? Anyone else notice this?
Pulled out the Durametric to log some data. Any more data you would like to see?
At idle and up to about 3000 RPM FRA for bank 1 and 2 is 1.04.
Above 4000 RPM FRA goes to .98 for both banks
TRA for bank 1 is always -0.14 and for bank 2 -0.17
Hot film MAF 1.3 volts at 680 rpm idle, and 17kg air mass. On up to 500kg at 6000 RPM and 3.41 volts. (MAF was cleaned w/CRC cleaner during rebuild).
How do I explain this soot buildup in bank 1 but not bank 2 ???? It's driving me crazy !!!!!!
Brand new AOS dumping oil into the intake on bank 1 ???? (third AOS on this car). I meticulously cleaned all of the AOS tubes and completely overhauled the SAI system to boot.
Then again, perhaps I should just ignore the soot and keep driving it. At least I'm sure that would be the advice of some... but I can't seem to ignore it after sooooo much hard work.
One of my favorite quotes from this great thread is from Macster:
http://forums.rennlist.com/rennforums/997-forum/616049-exhaust-soot-oil-or-fuel.html
"For street cars as long as the engine's running ok, the CEL is not on, flashing, the engine exhibits no untoward behavior, oil consumption is within the allowed range, fuel consumption is in expected range, and coolant is not disappearing into the engine, the exhaust tips could be plaid for all that it matters."
Bank 1 Tail Pipe (looks blacker in person, camera is brightening it up)
Bank 2 Tail Pipe
