Danyol
About Danyol
Contact Methods
  • Website URL
    http://
  • ICQ
    AZ
    '03 Turbo
    '07 Audi Q7
    '63 Austin Healy Sprite
    '74 MGB
    '89 Toyota Supra T
    '01 Audi A6 4.2
    '02 911 C4S
2,262 profile views
Danyol's Achievements
  1. Anything else happen leading up to this (flooding, rain ect)? Check the big harness connectors on the right of the engine bay, re-seat them after making sure all of the pins look good. Check the ECU ground. I'm thinking the sensor is a symptom not the cause.
  2. If it's definitely the same wire, it is either open circuit or (less likely) the ground is not a good one.
  3. Fluid transfer and overflow to the front reservoir is typically a slave cylinder issue.
  4. Ok, I have 2003 with PCCBs. Yes the dust buildup will make them noisy, a wash often helps. Take a look at my brake squeal DIY on another contributor. On the drag, remember the car is AWD, the 2 front wheels are connected through a differential, you turn one wheel the other wheel will turn in the opposite direction. Much more inertia and "drag"
  5. Good grief guys, $6 for a 10 mm o-ring :huh: Anything special about it? I've reused them in the past, contemplated just using a plain nitrile ring, is it viton or some other exotic?
  6. Guys, there is another option that may fit some, this is listed as a "race" tire but I understand from a couple of local turbo guys it is good in the wet and wearing very well (combination of road and many track days, still lots of tread), the Federal 595 RS Racing tire, Although the largest rear tire is a 285/30-18, with many tires the actual physical size is often different between manufacturers I can confirm having seen the tire, even though it's listed as a "285", it is closer in size to a 305 in Hankook (prob. around 300). They are available online but usually on back order, you need to plan ahead. A a full set < price of 2 PS2s
  7. Looks like you could make a "tab" onto the light out of epoxy, then drill for the screws. This could be colored and shaped the same as the original.
  8. I ended up purchasing Kevin's (UMW) logging platform to get the whole data set at over 50 samples a second. When I originally used the Durametric for logging (V6) I was able to log 6 - 7 different parameters during test drives, It appeared to be achieving around 8 samples a second. I have an older (Centrino dual core) laptop running XP, but I have upgraded the hard drive to SSD which I think helps (I'm running an Intel SSD).
  9. Guys, Thankyou! - The gas cap has been replaced a couple of times - Trying to follow DME diagnotic procedure on leak checking but have no diagram. - The car has spent time at an experienced Pcar shop, exercised all the system diagnostics using a Porsche tool. Everything appeared to act normally during all the actuation tests. Loren, "Check ventilation line on tank - Remove battery. - Remove battery cover. - Check whether ventilation line is attached to the fuel tank sender unit." On the turbo, the connections are under a square cover in front of the differential. Are there connections under the battery tray we cannot see, in particular, where is the pressure transducer? Thanks!
  10. Alternate tires - have Nitto NT-01 with 315-30 and 245/40; I had clearance but added 5mm spacer on back just to be safe.
  11. Guys, I've been helping a friend with his 2002 TT and a very frustrating (intermittent!!) P0455 DME code. He needs to get through emissions inspection, in AZ they just connect to the OBDII port and the system won't show a "ready" state so it will fail. We've seen several references to what the problem could be, just trying to narrow it down. We have the DME manual, shop manual (I thought it was complete) and completed a lot of research on the forums. Some things that will help, - We need a full drawing of the tank vent system with the location of components; where is it in the manuals? - References online indicate the simplified system for detection is as the attached. Where is the pressure sensor "5" located at? We've looked around the tank and the evac canister, doesn't appear to be anywhere near. -We hear some kind of pump that comes on with the ignition, is that part of the evac system, where is it?
  12. I don't think Vivid would have given you an inappropriate tune if you stated your car was otherwise stock. Go back to basics, we have 7 - 8 year old cars the new tune will place greater demands on all the parts, they better be in the best shape. Areas to look at in these cars are plugs, coils, MAF, bypass valves, boost hoses. By adding 110 octane all your doing is changing the speed of burn of the fuel, altering the timing needs.
  13. Higher cylinder pressures ect you have more loading at the higher tune. If you have the original factory Beru plugs or they haven't been replaced in the last 20 - 25k I bet it's that and/or coilpacks. I'd do both.
  14. A) Whose tune is this? B) What does the tuner have to say? A flash has impact on so many factors this could be timing, fueling, boost leaks and many others besides.
  15. I was in the same boat as you 3 years ago. I did find one co to insure me, then rejected due to 19" wheels! Oh yeah, they don't cover wear items, how much expenditure is due to that (they decide). Three years now i've had a window actuator fail and a clutch accumulator. Neither of these are high $.
