Mitty
Everything posted by Mitty
  1. Has anyone got experience with this: Quaife 996 6-speed ATB differential
  2. Norton-sp, let me know how it goes. Tool Pants, thanks, makes sense now, thanks!
  3. You got any information that we can look at about this software? What are the hardware reqs? Thanks, Darren
  4. Here is his feedback. The numbers are there, but you just cannot read the comments.
  5. Loren or anyone, When I bought my car, it didn't have the PCM 1 manual. It would be nice to have. Anyone have this in PDF format? The "Porsche Manuals" section is pretty complete, but no PCM 1. Thanks, Darren
  6. What kind of options are there for PCM1? I would be happy to help with any testing you need. -Darren
  7. I don't have PSM and would like to see that diag too. Thanks!
  8. I did. Let's talk about it "out loud" so other people can benefit. -Darren
  9. gapper = $.99 at <your favorite auto parts store> Better to check than have the engine not get the proper spark.
  10. Curious: What would happen if I disconnected it? CEL? Bad for engine? Rough engine until warm? -Darren
  11. My car didn't come with a manual for the PCM 1. Anyone got it in PDF?
  12. How do you go into setup on PCM 1?
  13. Guesses: Valet switch for an alarm Extra lighting A/C shut off Cigarette lighter switch for normal/key switch/off Robocop style shocking alarm system switch
  14. Congrats on the car, it looks awesome! :thumbup: Well worth the wait? There is a popular shop that does custom systems for Porsches. Car Audio Innovations. If you call Rob there at 1-800-892-6430 he will be happy to discuss your needs. He can sell you a box that will fit nicely. Check out some of the installs on their web site. Not sure if you will get your 12" in there, but he has done an 11". You will have to talk to him. -Darren
  15. I got the Digimoto software. It runs on my laptop and got the PocktPC version too. I bought from an eBay auction they had going. Worked for me. -Darren
  16. I get charged for an hour diagnosis for the horns not working. They (OPC) say my horns are bad. I take my car to an independent for another problem (long story, new engine when it was all over (rod bearing)). When I get the car back the horns work! I asked them what they did, they said “replaced the fuse”.
  17. How did you get your car to levitate? Very nice, how do you keep the underside so clean? -Darren
  18. Possible reverse lights problem: The reverse switch screwed into the top of the transmission has been known to fail. Mine did. It is a cheap part to replace. I pulled mine out, connected the plug to it and tested the pin switch by pressing on it with my finger. The reverse lights worked. Put it back in the car, no worky. The reverse engagement mechanism isn’t pushing the switch all the way. -Darren
  19. Any more noises? I just started getting this clunk - clunk - clunk sound from the engine, next to the right rear wheel (not exhaust). I was about 100 miles from home on the coast. Cold idle was a bit rough. Almost seems as if one cylinder is missing. No CEL. I get home without any problems. The engine sounds smooth, however there is a burnt rubber smell coming from the engine. Not a clutch smell, I know what that smells like. I reach in and touch the belt and it is not warm. The conditions were wet. 56600 miles on the engine. 6 months ago I had a coil and oil bellows replaced. Oil lever looks good. Ideas? Thanks, Darren
  20. I agree. However, if I wanted a few things painting (center/rear console for example), it might be worth talking to Eric.
