SNaray8442
Everything posted by SNaray8442
  1. Is the dealership the only shop likely to have that tester?
  2. I've still got this code. Any other suggestions?
  3. I've got a whole nother thread about the codes. I've done a lot of troubleshooting and haven't found anything.
  4. 1999 C2 US Codes P1124, P1126
  5. Mods are only a K&N CAI and PSE
  6. Sometimes after a high speed/rev run my car will just die. I'm not over-revving it. It just dies and I have to restart at high rate of speeds, not safe. Any ideas? MAF? No codes. Thanks!
  7. Code came back. Took much longer this time, but the same P1124 and P1126 are back. Any suggestions on what to look for next? I've already put it on a smoke machine, showed no problems. Thanks!
  8. The control unit is for auto-leveling I presume? Is it too much effort to install? Thanks for all your help, you're great.
  9. I recently purchased a pair of litronic headlights got my 1999 C2. I've noticed that there is an extra plug on them that I don't have a harness for. Where can I find the parts and instructions to help with this? Thanks!
  10. Savannah interior. Once a tan, now kind of a mustard yellow. Is there any product or technique to correct this? GOOD BAD
  11. I think I've found the culprit... and you'll never guess what it was. ..... ..... oil cap?
  12. I think I've got the same problem here. Strange AC related noises.
  13. So my CEL hasn't come back in quite some time. It seems like every time the code is tripped is when I've been on the highway, get off, throw it in neutral and coast to a redlight.
  14. Agreed, what cult? Perhaps some internal advertising would be helpful.
  15. Are you sure you're turning the correct "nut"? Do you hear any loud POPs when you turn it?
  16. I've got this problem now as well. Happened all of a sudden as well.
  17. Nobody local has anything that they'd let me use to read my fuel trims and whatnot. Any ideas what else to check for? Seems like drivability is pretty normal to me.
  18. I'm not sure about the iPod ID3 tags, but as far as the sunglass holder goes, just pull it harder.
  19. I've got an intermittent "clicking" from under my dash, in the center. It goes away when my AC is off. When it clicks, the AC LCD flickers as well. Any ideas? A blower motor on the run?
  20. I don't have a scanner unfortunately. I'll try to find one locally.
  21. I haven't found any leaks and I've run a tank of injector cleaner. The code came back. What next?
  22. Got it, thanks. You guys weren't kidding about that taking patience, whew.
  23. I don't have any female torx bits, will any hex sockets work?
