mikefocke
Everything posted by mikefocke
  1. A classic cause of not starting when hot is the crank position sensor. If it is not working the tach will not bounce even a bit when the key is turned. Repeated attempts could have killed the battery. Good luck.
  2. A 3.2 of what year to a 3.6 of what year? Year to same year swaps of 996S to 986S are relatively easy but different engine generations result in some wild and lengthy threads on the forums with sometimes no resolution.
  3. 1. CPS sensors are notorious for failing at high temperatures, cooling off and working again until ..... 2. The tach not bouncing is another sign of a probable CPS sensor failure. Several of the forums have folks who posted the diagnostic methods of checking voltages on the CPS.
  4. When it doesn't start does the tachometer bounce at all when the key is turned? Are your radiators clear of debris?
  5. Those codes are the key and the people who are trying to help you have collectively thousands of Boxsters experience and the manuals to help you if you help them. POST THE CODES.
  6. You have a 650 or a 605? With the 300 series codes or without? What model year and engine? Any mods or recent changes?
  7. Battery charged, turn key. Does the tachometer bounce? Do the sounds tell you that things are spinning?
  8. Several options depending on your budget. Double DIN Pioneer with kit can give you a modern bluetooth interface, XM, sat nav, etc. On the other end there are adapters. How deep are you wanting to go? Browse a crutchfields web site to see some kits and prices for the former.
  9. What maintenance history do you have for the car? Done things like leakdown test, scanned for current or pending codes, pulled the oil filter and pan and inspected for debris? Alignment? Cam deviation? Has a professional Porche experienced mechanic driven the car? How old is the clutch? Condition and age of tires? Brake fluid age? Oil and filter? Where I'm going with these questions is you need to get where you really really know the condition of the car. What is your height relative to the rollbar? Have a hardtop? What are the rules of your local track and race sponsoring association?
  10. By housing I presume you mean the circuit board like thing that the bulbs and wiring plug into. Your description says there are two functions that may not be working. One is a fog light and I presume you know that is only one side of the car and not both. I forget which. But if one is lit, you ignore the other. The other is what are sometimes called running lights. The light that is lit when the headlights are on and the brake lights are off. That is likely to be a connection at one end of the harness or the other assuming the other side is working. Could also be a chewed wire in the harness.
  11. Note that the TSB6924 may not be the latest technique for fixing the grounding problem. I had the same issues you had and had both buckles and TSB6924 applied and still had the warning light. I took it back to the dealer and they fixed it using some verbal fix (but not any parts that were documented) from the Porsche regional tech. Unfortunately that was probably 11 years ago and I have no records or memory beyond a note that this was their approach and it did fix the problem for the next 6 years.
  12. The 6-speed and 5-speed used lots of different parts in the rear and wheels to accommodate the 6-speed that were different from the 5-speed. Why do you want the 6-speed? (There are those who prefer the ratios of the 5-speed.)
  13. Credit Maurice/1stchoir who provided the material. All I did was host them.
  14. Yes the behind the seats panel is unaffected by the hardtop. But compared to the hardtop, the choice of a mid engine design had much more consequence in terms of ease of maintenance. So it all depends on what you want and most choices have downsides as well as upsides.
  15. You have the PET available for free here. Move down on the page and enter your model type "Boxster" and year "1997-2004" and it will offer a download of the parts manual with cut away diagrams.
  16. I suspect if I pulled up behind someone on a clear night who had the rear fog shining in my eyes I'd be flicking my brights at him and seeing how he liked it. Both invite confrontation. Rear fogs are for safety in fog and not for irritating others. I suggest DRLs pointed at the edges of the lane as not irritating anyone yet effective in the front.
  17. A 2001 with a 3.4 must have had a 996 engine transplant. The 2003 was the first DME 7.8 Boxster engine
  18. A handy reference is here. It lists 5 possible ways to get in the front trunk.
  19. Try pulling on the emergency trunk release cable with someone pushing down slightly on the hood (front trunk cover, not the top (got to account for the UK folks and their descriptive terms))
  20. Crutchfield's is still around in Charlottsville and they have a web site. They sell a wiring harness to adapt the stock wiring to the radio and know Porsches as they have done many in their shop for the UVA folks. There was at one time a dealer in Charlottsville again contributing to their familiarity with P-cars. They will provide car specific instructions for the DIY install. PCM is so outdated for most buyers today and it isn't like a Boxster is a car you'd want to keep stock for future price appreciation.. They have a web site and offer phone support.
  21. For those reading this thread in the future, the MAFs for the 2000 base and S vary according to the build date. The 124.00 part number is for: Early 2000 (1/31/2000) (thru Boxster 2.7L Chassis #98 6YS 62 0414 and #98 0YU 62 5099) (thru Boxster S 3.2L Chassis #98 0YS 66 0257 and #98 3YU 66 2413) And if a 125.00 or 125.01 part is used for those cars, a reflash is required. Is the car has a 125.00, a 125.91 can be used without a reflash. This can be verified by consulting the PET.
  22. Do you have the old MAF? Was it a -124 or a -125? Because there are two MAFs for the 2000 model year depending on the chassis number. The info I had for the -124 (the one that needs the reflash if any -125 is substituted) is: "Early 2000 (1/31/2000) (thru Boxster 2.7L Chassis #98 6YS 62 0414 and #98 0YU 62 5099) (thru Boxster S 3.2L Chassis #98 0YS 66 0257 and #98 3YU 66 2413)"
  23. LN suggests using a filtermag. Lots more surface area. More expensive though. Drain the particles on a paper towel. Then test with the magnet. Metal particles can be copper, iron or aluminum. And of course there are plastic coatings and pieces of sealant.
  24. And why was the IMS done? Problems or just proactive? Was a qualification done (inspected the filter and pan) before the replacement? How long have you had the car? IMS done on your watch? What kind of oil filter? Sadly, there are people who throw a LN in a car that had a failure and sell it on quickly before scattered debris from the earlier failure can show up.
