juniinc
Everything posted by juniinc
  1. about $60. U could hack it to work when the wiper is on.
  2. 4th funtion will be eliminated since there is no remote. Nope I haven't purchased it yet. Yes I sure will post some pics if I do it,,, I wonder if you can have the same functionality on a car that doesn't have the keyless entry remote. Did you buy Sens56 Juniinc? Can you do a DIY write up when you install it so that the rest of us have a better idea on how to install it? I would like to hook one up too.
  3. I believe there are 3 micro switches per door. need to remove the door panel, switch is located just behind the door handle. Do a search, U will find a lot more info. The best 1 is "driver door glass strange behavior"?
  4. U can only get em from a few asian countries. gmarket.co.kr Where did you get them? --Brian
  5. yup , pretty good idea,,,I think its time for u to pay a visit to Radio Shack. Also if tapping with the relay is too complicated, might get away by using the phone ready power inside the center console?
  6. probably the door handle micro switch,,,
  7. I put about 3500miles back to back from Seattle to Los angeles. She loved it, 1000miles a day rarely stopping
  8. found in RLEAY SUPPORT 1, refer to Terchnical group 9, Circuit Diagrams upper left corner is your relay BS 16/2
  9. thanks RFM & sixter! I like the security delay feature + as U mentioned it also has a day running light feature. Hey mike I feel the same way about the parking lights , I can just eliminate that in a few seconds!
  10. most dealers will avoid doing that,,,even if U talk em into it, they won't cover the part
  11. OK fellas, it's been a few months since I've done any modification to my "Baby Kathy" I'm constantly thinking to upgrade/modify my 986S,,,As usual I need all U member's input & will be greatly appreciated! Thinking about throwing a AUTO HEADLIGHT SENSOR - General Information: · When the environment starts getting darker, the system will turn your low beam headlights on. Vice versa when environment lights up. · In the day time when you drive into a underpass, subway or any dark environment, system will quickly (0.25 milli seconds) turn your park and low beam headlights on. · At night or in any dark environment when you turn your engine off, it will keep your park and low beam headlights on for 25 seconds as follow me function in order to guide you in the dark . in the dark your headlights will be on when you unlock your doors from remote Is this hack worth it or not?
  12. U still haven't said how much the kit+wire hardness cost?
  13. How much is this whole anti-dazzle interior mirror kit thing? B) The one I ordered is about $60.
  14. Anytime lucky, yup I thought it would just be something with /R, so double checked,,, It's the same one
  15. I see , just read that TSB. U only need to access the central alram module lead for the reverse gear signal. I wouldn't even mess with that if I were U. I'm doing a auto dimming headlight senor+auto interior sensor here soon(OEM parts too$$$/100% unversal parts modified) So I will need to access my alarm module in order for the headlights come on when I unlock the car+stays for 30 seconds when locked.
  16. I'm just wondering why removing your driver seat? if U are, try not to disconnect the wire hardness. most times air bag light will be tripped
  17. rock solid? I don't think U want it like that,,, normally in heavy traffic, its suppose to rise a bit from this position
  18. there is an emergency cable when U open the passenger door
