Dennis C
Dennis C last won the day on March 17 2019
Dennis C had the most liked content!
About Dennis C
  • Birthday 03/22/1966
  • Interests
    Dallas Cowboys football, Skiing, Fly Fishing, Guitar
    Evergreen, Colorado
    2014 Porsche 911 Turbo S Cabriolet
    1979 Alfa Romeo Spider Veloce
    2002 Porsche 911 Carrera 4S
    2004 Porsche Cayenne S
    2004 Saab 9-5 Aero
    2008 Porsche 911 Turbo Cabriolet
2,658 profile views
Dennis C's Achievements
  1. Hello all. I am considering replacing my OE mirror cap with a carbon fiber cap. The vehicle is a 2014 Turbo S Cabriolet. I have the power folding mirror option. Is the cap the same part as the standard mirror, or is it different? Thanks!
  2. My Turbo S was serviced last week at my local dealer for this issue. According to the dealer, there are no faults in my system. There are no TSBs, as mentioned above. The behavior my car exhibits is normal. The dealer said that this is not an uncommon concern. PDK is technically an automated manual transmission, as opposed to an automatic transmission with a torque converter. As a result, there will always be a little bit of slip as the clutches engage from a dead stop. He did say that the transmission learns and adapts to the driving style of the driver, so maybe I've babied the car a little too much. I may try starting quickly for a few weeks and see if anything changes.
  3. Thanks Loren. I've got a service appointment next week. I'll report back after the appointment.
  4. I've begun to notice that my PDK appears to slip or hesitate sometimes, most notably when I accelerate from a standstill. The engine revs, but it takes a second to engage and get moving. Has anyone else experienced this? Is there a TSB, or perhaps a software update for PDK that could help with this issue? The car is a 2014 TTS.
  5. Thanks again for the help. I was able to loosen the bolt and easily adjust the tip. It uses an external torx bolt (I don't remember the size).
  6. Thanks Loren. I can see that clamp and bolt when I look under the car. I can see lots of the other plumbing too, so I just wanted to make sure that I loosen the right clamp.
  7. My recently acquired 2014 Turbo S Cabriolet appears to have a misaligned exhaust tip on the driver's side. I'm not sure how it happened; it doesn't appear to be damaged in any way, it's just canted a bit too much towards the outside. My question for the group is:. How is the tip adjusted? In the past, I've simply loosened the clamp that attaches the tip and then moved the tip into the correct position. I looked under the car and it looks a little bit more involved for the 991. Is it the same as my 997 was in terms of adjustment? If so, does anyone know the bolt size? Thanks!
  8. Thanks Loren!
  9. I replaced my OE exhaust tips when I bought my 997.1 TT and I've decided to go back to the OE tips. Is there a guide for proper placement? I want to make sure that they are aligned properly and they they extend the proper distance from the opening in the bumper cover. Any help would be appreciated.
  10. I did finally get the car into the shop for the cruise control issue. It was a software issue that required some reprogramming by the dealer. Everything is fine now.
  11. I haven't sorted it yet. I've checked the brake lights and that's not the issue. I did speak with my dealer and they are going to take a look when the car goes in for service.
  12. It's still inoperative, but I noticed that the green light in the instrument cluster does illuminate at start up. I'm beginning to wonder if this is an issue with the control stalk... I think a trip to the dealer is in order now.
  13. Hello everyone. My cruise control is not working on my 997 TT and I'm hoping it's something simple. The car is under warranty and I'll take it to my dealer if necessary, but I want to make sure I'm not missing an easy repair before I do that. The green light in the instrument cluster will not illuminate when I attempt to active cruise control. I do have Depo LED tail lights installed, and they work perfectly without any error messages. I've read about LED tail lights causing problems with cruise control so I reinstalled my factory tail lights to see if that would change things. It didn't. I've checked the fuse box and there isn't a fuse specifically dedicated to cruise control. One obvious candidate to me was the fuse for the brake light switch (fuse C4), but that fuse was fine. I also checked fuse B3 based on a search on these forums, and it was also fine. I would greatly appreciate any suggestions.
  14. I ended up replacing the entire system in my 996 C4S, including the head unit, amps and speakers. I went with a Kenwood unit that allows for Sirius/XM, Bluetooth with voice activated dialing, iPod/iPhone connectivity, Pandora compatibility, etc. It was expensive, but it was a nice upgrade. One thing to keep in mind is that the interior cabin noise of the 996 makes it very difficult to use a handsfree phone. The engine noise and road/tire noise are excessive compared to more modern cars. This makes it very difficult for your callers to hear or understand you. If your main purpose for spending the money is for Bluetooth phone connectivity, then you might want to rethink your plan. You would be happier with a nice bluetooth headset. Your callers would be too.
  15. I think you'll need to replace or modify the front fenders too. I haven't done this personally, but I've read a few posts about it. I think you should research it a bit more before you pull the trigger on the parts.
