vwboratt
    2004 porsche cayenne s
vwboratt's Achievements
  1. I have a 2004 Cayenne S, and have been having a problem with the driver's side dip light going out. If i pull the head light out and put it back in place it seems to work for a couple of days. Has anyone else had this problem? Thanks!
  2. Does anyone know where i can purchase one of these for a 2004 cayenne s? I have been searching and can't seem to find any. thanks! Brian :D
  3. What are TSB's and where can I find them to read?
  4. Has anyone experienced wind noise coming from the passenger side window/mirror around 55 mph? I talked to the dealer today and he said he would check out a vehicle that he had on his lot to see if it made the noise, he emailed me back and said that there was some noise but he still wanted to see my vehicle to make sure it wasn't abnormal. thanks
  5. Does anyone have this same problem with there cayenne? There is an air noise coming from the windshield on the passenger side of my 2004 cayenne s. Very annoying, just wondering if it was an easy fix. It almost sounds like the windshield isn't sealed. But i dont have any water leaking in. thanks
  6. Has anyone changed the air filters on the 4.5 v8? and if so can anyone help me out so i dont mess this up? I want to change to the K&N filters and when i was checking out the air boxes i figured i would ask first. Thanks
  7. Hi, I bought one off of ebay, an uncut key with remote. the seller was remote hub, and I took it to the dealer to get programmed and cut, and they told me it was a deffective key and couldn't be reprogrammed, so i was out 75 bucks. So i then ordered one from the dealer and it cost me $200 for the key and $85 for them to program it. My original key was beat up really bad and they replaced it under warranty. So i would check with the dealer to see if they will cover your beat key under your warranty. Hope this helps! :thumbup:
  8. Hi, I just bought my first porsche cayenne s, used and I only have one key. I just bought an uncut key with remote and wanted to know how much it will cost to get it cut and programmed. And also is this something the dealer can do or must it be sent away to be done? Thanks :D
