Jeremy Cottrell
    Los Angeles
    85 Carrera
    72 RS replica
  • Future cars
    930 Turbo
    993
    996 GT3
    72 911T 3.0
    914 1.7/2.0
    914-6
1,162 profile views
Jeremy Cottrell's Achievements
  1. Hi Guys, Have a 2008 Cayenne V6. Car runs fine but codes for P12A2. (Fuel/air metering). Car has a new valve cover (oil separator), new intake manifold gasket and new high pressure fuel pump. Anybody else had this one??
  2. Any resolution on this? I too have the Side Servo Motor code.
  3. Any resolution on this? It's kinda like reading a book only to find the last page torn out.
  4. Yes. 1126 comes back. It takes awhile but it comes back. It may be one of those situations where whatever the problem is it will need to get a little worse to actually find it.
  5. I went down the road in the car. FRA was 1.00 to 1.04. At idle 1.00 steady for both banks. RKAT for bank 2 got up to 0.75%, bank 1 stayed at -0.05%
  6. FRA is 1.00 on both banks. That's interesting you mentioned EVAP control system. This car has trouble at the gas pump. It only takes a couple gallons at a time.
  7. The car is a 2001 Boxster non-S with a code P1126. RKAT readings for bank 1 are 0 RKAT readings for bank 2 are 0.58 MAF is around 13 - 14 Looks like we have bank 2 running a little lean. Checked for vac. leaks, nothing found. Checked AOS, no leaks, oil cap easy to remove. O2 sensor voltage all ranging .27 - .89 V O2 sensor resistance: Bank 1 - ahead of cat = 384 ohms Bank 1 - behind cat = 64 ohms Bank 2 - ahead of cat = 64 ohms Bank 2 - behnd cat = 128 ohms I cannot find any data for the resistance numbers. Any idea if these numbers are just as a result of the lean mixture or a problem with an O2 sensor itself, or ??
  8. Does anybody know where the outside temp sensor is on a 93 964? I have heard it was in the mirrors so I took both sides apart and nothing. Using a PST2 I am getting a code 16 - Outside temp sensor, and when I check it in actual values it just says signal impluasable.
  9. Sorry to bring up an old thread but I have a 05 V6 which had this code along with a terrible running problem. I replaced the MAF, the car runs great now, but it still codes P1096. Where is the ambient air pressure sensor located?
  10. I am having this same problem. I tried recalibration 4 times and was able to reset the system with the Durametric, but the light keeps coming back with codes 4440 and 4444. Any ideas?
  11. Any ideas? The car just cranks and cranks but does not fire. My Durametric doesn't read the DME on a 2008 and later. Car sat for 10 days, but the battery is great.
  12. 08 Cayenne V6. When cruising or accelerating slightly there is a clunking feeling which seems to be coming from the driveline. It is somewhat intermittent and seems to be doing it more after the car has been driven for awhile. The car has a new driveshaft. There is no clunking when turning like would be exhibited by a bad stepper motor. Any ideas?
