sir16
Everything posted by sir16
  1. i have one too,,, and would like to know
  2. thank s alot :renntech:
  3. i just wonder if the rear '' brake wear sensor'' , is it the same in the front ?????? thank s
  4. im a buyer if you sell these headlights
  5. 2000 c2 tip, 127000miles runs and drive perfect !!! :renntech:
  6. thank s alot ! that will help me !
  7. i know that the headlamps are all assembly (lights ballas ect)... there s the usual plug on the side,,, and the one missing is the one going in the ballas, so that the one for the control unit ?
  8. i just both a pair of litronic headlamps from a 2001 boxter...now in my 996 c2 2000 it seams that there s a plug missing for the xenons ????? is it normaly there?
  9. i use 5w30 mobil,and no problem,im close to 100 000miles.little noisy,at idle ,but it looks like the injectors .
  10. i use a pry bar to move the tensionner....i d ont think it s the right way to do it.....what it the right way...? doe s it take a special tool ? i did a reseach ...with no result. ok i find someting in'' polyrib belt change'' but my 24mm bolt turn on itself with the 15 mm in the back so it s impossible to move the tensionner ...
  11. its was time to change it belive me !!!! thanks loren
  12. ok i took the strap and the tensionner bearing assy out,,,,the tensionner: (pully bearing assy is 70$) not bad,but the thing is :i had to move the car up in garage for the night with no belt.... about 10 ft......now my abs and bat light is on..... disconnecting the battery will it reset it s self ? :o
  13. already did and still sweat.... thank s for the info
  14. i need info on that sensor (oil temp,...oil press ????) on my 996 c2 tip ,and part number if possible on seal or gasket, is it a common leak?,......things i need to know before fixing this .... thanks
  15. well, i will check mine,beacause it think it s noisy
  16. now every is just fine ,runs a1
  17. finaly got my code 5201
  18. there s no ratle,the car response is good at all rpm range,the variocames kick s, it look like a 996 tiptronic in good shape run s arond 14.2 sec for 1/4 mile. so im not that far.
  19. it s the o2 sensor,but wich one ,i dont know ? there is four of them i think. the code for it ,i dont know,its the privious owner that did the diagnostics.
  20. here, up north in montreal canada,today it was a cool day about 22 celcius
  21. my 911 tiptronic 996 2000 today at 1/4 mile. 14.45 @ 102.49 mph my ''check engine'' light is on du to a o2 sensor maybe it s afect the performance what is the stock 996 time ?
  22. here s what i did, i jack the car on one side (rear) a bit, the car was hot (driving for about 1 hour),drain all the oil,fill it up with 5w-30 mobil 1 (8.5l), drop the car down,than i start the car and it was runnig bad at idle......,so i took it for 30 min ride and now it seem to be runnig better is it normal ?
  23. hi loren,i did it and it wont work,i will try it back or is there a poss of a nother code?
  24. hello, i need the code for my radio,can anybody help me ? becker 1 type: 4462 48\98 ser: x5018077 thanks in advance !!! vince
