sir16
About sir16
  • Birthday 07/30/1977
Contact Methods
  • Website URL
    http://
  • ICQ
    montreal canada
    Other
    porsche 911 2000
    nissan 350z raodster 2004
    silverado 1r500hd 2003
  • Future cars
    porsche twin turbo x50
    nissan 350z hard top
    skyline gtr
    honda s2000
623 profile views
sir16's Achievements
  1. i have one too,,, and would like to know
  2. thank s alot :renntech:
  3. i just wonder if the rear '' brake wear sensor'' , is it the same in the front ?????? thank s
  4. im a buyer if you sell these headlights
  5. 2000 c2 tip, 127000miles runs and drive perfect !!! :renntech:
  6. thank s alot ! that will help me !
  7. i know that the headlamps are all assembly (lights ballas ect)... there s the usual plug on the side,,, and the one missing is the one going in the ballas, so that the one for the control unit ?
  8. i just both a pair of litronic headlamps from a 2001 boxter...now in my 996 c2 2000 it seams that there s a plug missing for the xenons ????? is it normaly there?
  9. i use 5w30 mobil,and no problem,im close to 100 000miles.little noisy,at idle ,but it looks like the injectors .
  10. i use a pry bar to move the tensionner....i d ont think it s the right way to do it.....what it the right way...? doe s it take a special tool ? i did a reseach ...with no result. ok i find someting in'' polyrib belt change'' but my 24mm bolt turn on itself with the 15 mm in the back so it s impossible to move the tensionner ...
  11. its was time to change it belive me !!!! thanks loren
  12. ok i took the strap and the tensionner bearing assy out,,,,the tensionner: (pully bearing assy is 70$) not bad,but the thing is :i had to move the car up in garage for the night with no belt.... about 10 ft......now my abs and bat light is on..... disconnecting the battery will it reset it s self ? :o
  13. already did and still sweat.... thank s for the info
  14. i need info on that sensor (oil temp,...oil press ????) on my 996 c2 tip ,and part number if possible on seal or gasket, is it a common leak?,......things i need to know before fixing this .... thanks
  15. well, i will check mine,beacause it think it s noisy
