extrememoto
About extrememoto
    2000 Carrera 4
7,092 profile views
extrememoto's Achievements
  1. Could someone help me locate the reverse signal wire in the cabin of a 997.1 manual transmission?
  2. mine too, 06 C4S. Maybe apply some RAIN-X on the windshield?
  3. Just completed the exhaust mod with 2 inch pipe across the inlet and outlet pipes on 06 C4S. It sounds pretty good, but personally, I think it is a bit loud specially when the top is down, perhaps a smaller diameter would work better. Here is my question, is there any performance hindrance with this mod?
  4. not sure, the clutch feels pretty good. the car only has 8000 miles.
  5. the clutch pedal on my 06 C4S travels far down, there is a good 2 to 3 inches of dead zone before the engagement. I have noticed a bolt sticking out from the floor right behind the clutch pedal. Has anyone try to make a pedal stopper or knows where to buy one if it's out there? thanks
  6. Hi all, I have a 2000 Carrera 4. As far as I know in 2000, there is only one engine to choose from which is 3.4 flat 6. Just cleaning the car the other day, and realized a sticker under the engine lid which showed Displacement 3596 cc. Can anyone help me understand this? thank you.
  7. I think it's number 5. it goes right under the main bulb (headlight)
  8. I think I have mistaken the bulb. I meant the one inside of the Liptronic lamp. There is a small bulb in there, it turns on when with the parking lights are on. thanks.
  9. Hi, Can some one help me find the part number for 2000 C4 parking lamb bulb? Thank you.
  10. Loren, Is it the same part number for MY00 C4? Fuel pump 996.620.103.00? thanks
  11. The oil cap seems to sit tight and I can't see any crack on the oil tube visually. Is it bad to drive with a bad MAF, could it cause misfire? Yesterday the car had a flashing CEL, code read cylinder misfire, I let it sit over night, disconnect the battery to reset system and it seem to drive fine now. But whatever it is, I think I better get it fixed asap. ps. I have the durametric tool, and the RKAT readings are way out of the suggested value from the durametric people. I was told it's most likely a bad MAF, but I am suspicious of other issues.
  12. just got the MAF, installed it, disconnect the battery for 10 minutes. Drove for 15 minutes, CEL came back again, same thing. What else should I look into? Thanks
  13. yes, drives well with MAF unplugged. so I guess next step is to buy another MAF. Should I still look for vacuum leaks or the source of the problem since something has to cost the MAF to go bad in the first place?
  14. extrememoto, have you recently replaced the MAF? this code and the running condition you describe with no detection of a vacuum leak is usually a MAF. do one test and disconnect the MAF and drive it, see if it runs better. Let me know, Ron Yes, I did replace the MAF about 3,000 miles ago. I got it new from ebay, perhaps that’s the problem. I will try run the car later with the MAF off. Can I narrow this problem down to either MAF or vacuum leak? The filter is factory paper filter.
  15. extrememoto, have you recently replaced the MAF? this code and the running condition you describe with no detection of a vacuum leak is usually a MAF. do one test and disconnect the MAF and drive it, see if it runs better. Let me know, Ron Yes, I did replace the MAF about 3,000 miles ago. I got it new from ebay, perhaps that’s the problem. I will try run the car later with the MAF off. Can I narrow this problem down to either MAF or vacuum leak?
