mudman2
Everything posted by mudman2
  1. On my 04 a lot of things happened without thowing codes
  2. I think you may have a wheel sensor or strut sensor going bad (if air suspension)
  3. Never heard of this method of resetting adaptation before
  4. the pumps are in fact under the rear seats, you have to lift cutouts in the carpeting to access the covers
  5. you should be able to transfer the subscription to a new adapter but no way you can use the adapter, maybe the antenna
  6. Trev there are a couple of magnets under the cover surrounding the stick that controls location of transmission for the dash. Not sure if they do anything else What happens when you use the steering wheel controls ?
  7. If its what I think it is is the check valve which holds pressure on the gas system while you fill up. They fail and you get strange starting after a fill up
  8. The electronic thermostat fails on 957's Just had mine replaced
  9. I did read that the pumps had been updated but did not know they now had to be replaced as a pair, wow thats not cheap !
  10. The updated part number applies to post 2007 and has a different frequency. Pretty sure the second answer is no
  11. There are 2 antenna's connected to the rear of the radio, I would check to make sure they are both on. The antenna are inside of the rear spoiler which can be accessed by opening the rear GLASS and you will be able to access the screws which holds the top part from the bottom. Check for water damage or obvious mechanical electrical issues
  12. I had my S in deep dry sand, I had no trouble, PSM off, high revs and don't chicken out
  13. Sorry for the cross post but I could not find this online and think it might be usefull http://forums.rennlist.com/rennforums/showthread.php?t=753445&referrerid=14620
  14. buy the whole arm with the new joints in, easier
  15. They all lead back to the ac control unit. They replaced a lot of those in the early days under warranty, not a hard job since you can actually see it. Worth a try I would think.
  16. Try an oil change first and maybe a flush
  17. not all the time you can drive thru it if its only 1, any error codes ?
  18. Wow I would have said the things you already fixed. I would recheck the coils first, just a visual inspection
  19. Agree fuel pressure pre flight not setting up. Purge Valve or a fuel pump
  20. So what happened with the 957 08 + where those issues disappeared ?
  21. hesitation is the lovely design feature of early 955s that we all hate. Many things contribute including the Egas Adaptation which can slow response to throttle. turn off PSM and drive it hard for 30 minutes and see the difference. Transmission control units can also slow response If you want to go fast "now" knock the gears down by hand
