bsavino
About bsavino
    05 m3
  • Future cars
    07 gt3
    97 m3, 01 m3, 05 m3,
bsavino's Achievements
  1. need some advice...did a track event 3 weeks ago, switched track to street pads, since the switch break pedal soft w lots of travel before they start to catch...during track event braking was perfect... i bled them 3 times since with both pressure bleeder and wife on brake pedal, but still soft w more than normal travel... what more do i need to do...ps i always started w brake furthest from master cylinder etc...both the inside and outside of the caliper...and took out a significant amount each time...have been bleeding brakes for a very long time, not a newbe and bleed them evey other event w motol 660............after the 3rd time there is some improvement in pedal but not the usuall feel...what am i missing...
  2. ok so after lots of research i found out something very important, there are 2 types (at least) of dvd navs, one that mounts horrizontaly and one that mounts vertically, if you mount either one the wrong way you will get very erratic nav operation, i unfortunatly got a horrizontal one and mounted it vertically in my gt3, i took it out and placed it flat (horrizonatall) and it works like a dream...now i know and you all know,,,,,,
  3. i just went to the pcm manual (see the manual section of this forum) and the nav fix works the volume of the nav syst with respect to the radio/stereo volume. i doesnt say anything about compass readings or navigation settings...
  4. i just went to the pcm manual (see the manual section of this forum) and the nav fix works the volume of the nav syst with respect to the radio/stereo volume. i doesnt say anything about compass readings or navigation settings...
  5. so i went to the nav set up and i dont have a nav fix, now what?
  6. I recently put in a pcm with ext dvd nav system all works well except the fact that the arrow doesnt always follow the map, it goes off on its own and doesnt follow the map when the car turns. i have the latest updates on the pcm and nav software. where is the problem?
  7. i guess not
  8. the porsche video on their site shows a chrono function....just wondering
  9. is there a way to view the chrono in the pcm if so how do you get it displayed on the screen?
  10. i have that tsb but i cant find the wores to tap into, my gt3 didnt have a CDC to tap into....
  11. porsche oem nav
  12. trying to retrofit a nav into my 997 GT3 only i dont know where to tap into to get power,,,,is there a harness lurking somewhere that i can use? of do i need to go all the way to the fuse box in the cabin. also is anybody did install this thing, where and how did they mount the nav dvd? Help...thanks bart savino
