99-996
Everything posted by 99-996
  1. Do you still have the starters? Mine is not retracting and making a wonderful noise...occasionally...but has been diagniosed as the starter. How hard was this to replace? It looks accessible... Thanks, Erik
  2. just went in to get tags and they ran my check engine light. it was an air sensor code on bank one??? the mechanic said it could just be a vacuum tube? is this something that i can do or check and if so, where do i start? car is 99-996 c2 Thanks in advance! Erik I think i can get the codes from the invoice they gave me.
  3. so i replaced the idler pulley and the noise continues. it still only happens when i start it and i can occasionally hear a trace of it when driving...barely noticeable when driving, not near the 2 second squeal i get at start. the tech said it might also be the air oil separator...the part is not expensive ($150) but i hear the labor quote at 6-8 hours. i had a friend start it while listening and it does sound like it comes from the alternator (which is why i replaced that idler pulley). guess i will try to replace that bearing that mkazemi71 was talking about.
  4. that sounds like a much more expensive hampster. i ordered the pulley and am hoping it cures it...nervously awaiting...
  5. my 99 996 needed a clutch at 45k and the rms was showing no signs of leaking. i had them replace it while they were in there and it is still tight at 65k. e
  6. A 300bhp hamster wheel to be sure. . . i hope after removal of this powerful creature i still have the same acceleration....if not i will re-instal that critter and begin a full marketing campaign for cheap hp increase!
  7. i also have heard of this...after further inspection, no hamster!
  8. Thanks Loren. i will call the dealer to get the number and replace that. Looks to be just the one bolt holding it there... i think i found them. there is an upper and a lower. they are $80 each. 996-102-118-56-M100 Drive Belt Idle Roller Upper (on Engine Console), Carrera (1999-05) (Tiptronic) Carrera 4 (1999-05) (Tiptronic) Brand: Genuine Porsche [More Info] 996-102-119-58-M100 Drive Belt Idle Roller Lower (on Engine Case), Carrera (1999-05) (Tiptronic) Carrera 4 (1999-05) (Tiptronic) Brand: Genuine Porsche [More Info]
  9. Thanks Loren. i will call the dealer to get the number and replace that. Looks to be just the one bolt holding it there...
  10. i think i have a pulley bearing going out on my 99 996 c2 cab. when i start my car, occasionally i get a loud squeal...not a belt. when driving at normal rpm (2500-3500) then let off i can hear what sounds like a squeaky hamster wheel... i think it is the pulley to the right of the alternator and under the oil filler tube. any ideas before i take it to the dealer. Thanks, Erik
  11. fuel gage at 0 might be due to the price of gas....that is what was wrong with mine! ;)
  12. thanks for that link Loren. i will pay close attention to the levels and temp...i hope this version of the coolant reservoir has not also failed like the last 9 or so versions.... thanks for the quick responses e
  13. you mean that little sensor located under the coolant res. that i tried so hard not to break when i replaced the tank last year??? looks to be in and plugged in...
  14. Hi all, i have had my 99-996 for about 30k and it currently has about 56k total miles. I was driving today and the red light on the dash, that is the high temp mark on the thermostat started flashing. the temp stayed perfect at the bottom (cool) side of the 180 where it always is (for about 12 miles home) but i have no idea what or why this has started flashing. i also checked the coolant reservoir after i got home and it seemed to still be full. i know this gets hot and expands and i checked it after a couple hours of cooling...same...still full. do i have another leak in the coolant system? any thoughts? Thanks, Erik
  15. Just replaced all 4 (pads) today. If you have any experience with tools, this is a very easy job. The only thing that I could add would be that even after you reset the pistons (the channel locks work perfect) the vibration dampers are stuck to the old pads and require a bit of careful prying to get them seperated which i found is the only way to get the pads out. After that it is smooth sailing. To make this a bit more accesable, turn the wheel all the way left to access the left side and vice versa...no way to make the rear easier. Also, I found that the new wear sensors were a bit loose when securing them to the new pads (outside front in particular). I secured them with some heavy two sided tape. I found that I only needed front sensors also and that the rear pads still had 30% wear left. Might not be the norm but I could have gotten away with just doing the front. Did the rear anyways. Was a fun job though...hope this helps! Erik :thumbup:
  16. Hi all, hope you are enjoying the holidays. Knowing i was low on fuel i was headed directly to the local pump when the throtle went unresponsive and the steering became nice and firm followed by the check engine light coming on...i was our of gas! I finished the trip to the station on my own power and fueled it up. She started up fine but the check engine light didn't go off. Just wondering if this is also something i need the dealer to turn off? With all the lights on my dash going on, i might be able to pass on a christmas tree this year. Thanks in advance for the trouble shooting. Erik
  17. Hey all, Out of the blue when i was driving, my airbag light on the dash came on and won't go off. I turned the car off and back on figuring it might just cycle but it is still on. My first question would be why did this happen? Should i be concerned that it is not functional? How do i fix this? 99 996 C2 Thanks, Erik
  18. Are you doing this on the floor? Cause its so much easier on a car lift. I dont recall any special adjustments needing to be made, put you will need the right clutch alignment tool. Good luck and have fun. vizcarra44 i have a friend that manages a shop and i can use the lift there...maybe some of his mechanics advise too. thanks,
  19. i saw that and it looked quite simple...i just dont know if the looks are deceiving. i just dont know if there are any other adjustments or alignments that are required after the new parts are in. that article didnt mention anything about adjusting the clutch after putting it back in...any advice on this would be greatly appreciated.
  20. Hi all, I am going to tackle my clutch on my 99-996 c2 and was hoping someone had some advice on this. From what I can tell it seems to be a bolt off/bolt on job. Are there any adjustments that need done after replacing the parts? Is the following seem to ba a complete list? I found it on ebay for $374 This complete clutch kit contains the following components: SACHS Porsche OEM Pressure Plate SACHS Porsche OEM Clutch Disc SACHS OEM Release Bearing SACHS OEM Release Bearing Kit Genuine SACHS Clutch Kit Part #: K70246-01-14 If anyone has advice or knows where a nice detailed step by step is Iwould appreciate it. Erik
  21. and i didnt break that sensor from the bottom of the tank....whew!
  22. Just finished the job...not that hard but you need some patience. took me just over 2 hours. removing those fuel lines are the key to the tank sliding in and out. after inspecting the tank i did locate the crack...it was on the bottom of the top tier of the tank right in the seam. thanks for the great diy instructions and the savings of about $500...that will go to my new clutch which i think i will try to do myself too. i read a diy on the rms and during the re-installation for the clutch i didnt see any adjustments that were needed. is the clutch just a bolt off bolt on job? erik
  23. great diy instructions...i was looking through the pictures and it looks as if a clutch replacement is a fairly uncomplicated procedure. can anyone shed any light on this or should i just pay the $1800 that the dealer wants? i found the clutch kit which includes # The following clutch kit includes: SACHS heavy-duty Pressure Plate (Made in Germany) # SACHS heavy-duty Clutch Disc (Made in Germany) # SACHS Release Bearing (Made in Germany) # SACHS Special Lubricant is this a diy project...do i need a lift or can i do it on ramps? how long did it take? again, great diy write up! thanks erik
