savvas_cy
    Cyprus
    Porsche Boxster
savvas_cy's Achievements
  1. Can you please give me a link that sells this suspension kit?I usually get parts from Pelican Parts because is the only one I found from USA who ship to Cyprus(Europe).But they dont have this kit. If anyone can give me a link from USA or Europe it would be great.
  2. I own a 1999 Boxster and I think I need new rear suspension.I hear a noise from there very often especially when the road is not smooth.Car has 95000 miles so I think to upgrade front/rear suspension. I made a search in forum but couldnt find any recomendations.I dont want stiff suspension.I need smooth ride and comfortable,if it can be comfortable ride in Boxster :) What do u recomend?To use OEM shock absorbers?I searched at pelicanparts and found out that OEM shocks absorbers are Blinstein ones.As I know these are very stiff,correct? Also I know that H&R suspension adjustable kit can be very smooth.Anyone tried this? I am waiting for ur comments and recomendations. Thanks
  3. I found the problem.It was the horn wire.So i cut it :) Now I dont have any horn sound when the alarm beep. Am I going to have other problems now? I hope not... Thanks for your help guys!!!!
  4. How can it be micro switch in door or in center console?central locking is workinf ok.All doors and hoods lock and unlock.The fuse blows just when the alarm try to enable the horn beep.I am not sure if my description make sense to you :) I am not an expert.I appreciate your help.Can you please tell me detailed what i have to look for Thanks.
  5. Sorry for the mistake in previous post. I meant is dry!No water no misture no nothing.Is really dry.
  6. It is not dry.I checked this first.2 months ago i change the fuse again and it was working ok.No probelms.Now as soon as the siren start the fuse is dead. I know I have to take the car to Porsche but will they know how to fix it? I am from Cyprus.I dont know if there are any persons that can fix Porsche.
  7. I figure out that when I lock my 1999 Boxster and as soon as the alarm goes on burns the fuse of the alarm/locking computer.Also when i press the lock button twice just before the brief sound of horn the fuse is dead again. That make me belive that there is something wrong with horn but is working ok.the alarm siren is working ok too. Does that mean that i need to change the alarm/locking computer.Is there a possibility to fix it or disable the alarm and just have a central locking? Please help me. Really urgent!!!! Thanks.
  8. I am facing this problem again now :( I tried to unlock my car this morning and couldnt unlock with remote key.I changed the alarm fuse and it was working ok. I came home after few hours.I enabled the alarm and after 30 minutes i heard the alarm beeping but without the traficator flashing and without the horn sound, just the alarm,for 10 minutes maybe.Now i cannot unlock the car with remote again.Probably is the fuse again bt this doesnot solve my problem :( Any ideas?What do I have to check or change? Please help me. Thanks.
  9. Ok guys i fixed it.I found the alarm/locking computer under the passenger seat and I change the 15A fuse.Now is OK.I dont know why the fuse stopped working.If the problem appears again I have to check where is the problem exactly. I have another question.can I adjust the sensitivity of alarm system?Its very very sensitive. Thanks for your help again!Without the forum I would put fire to my Boxster :). You help me solve 2 serious problem without any cost!!!
  10. We dont have rain here.is really hot with humidity.I dont know if this can ruin the alarm/locking computer.The carpet is not wet.Car electrician believes that there be somewhere fuse but he dont know where is it.First time he works on a Porsche.I really dont want to take it to lacal dealer.They are really expensive. So I will be very happy if you could help me to fix my problem.I checked the fuse in the fuse box.All fuses are ok.In aftrernoon I will remove seat and I will check fuse on alarm/locking computer.what else i have to check? As I mention central locking is not working,and lights dont open when I open door.Car is working ok without any other problems.But i really have to fix the alarm. Also how can I open fuel lid?I pull the emergency cable and didnt open.Maybe i make it in wrong way.Is there is another method to open it or I have to break it?
  11. By the way my car is right hand side and is 1999 nodel.The alarm system is under drivers seat or under passengers seat?How can I access it?Should I remove the seat?I try to find it and I couldnt see it.Where exactly is it? I want to open my rear trunk urgent!How should I do it?I try the screwdriver trick but I couldnt find any U things.I didnt manage to open it :( Please help me!!!I dont know what to do!!!
  12. Key battery is ok.The red light on th key is flashing when i press the button.And I also open the key and I measure the battery and its value is close to 3V. There is a lot of humidity here in Cyprus these days so propably is alarm problem.Can you tell me how can I access the alarm computer?what screws i have to unscrue and what I have to do? Thanks for your reply.
  13. This is the story: Yeserday i press the button to unlock my car.It didnt do ahything.Then I try second key.Nothing again.After that i used the key to unlock drivers door.Alarm didnt to anything and i start the engine.But i cannot unlock trunk front and rear.It looks that alarm,central locking and interior lights is not working.I thought that it was a fuse but all fuses are ok.What can I do?I manage to open front trunk from the switch under the front wheel.I unplug the battery for 2,3 minutes but didnt help. Please tell me what I can do. Thanks.
  14. Its white smoke and last for about 5 minutes and i think its not sweet smell.I think its oil.And as I mention temperature of car is ok and engine works really smooth and fine.Just the white smoke every time i start the engine
  15. You had smoke every time you start the car?Or during driving?You have similar oil leaking in the exhaust headers just like pictures above? By the way i checked the oil and is ok.No coolant.The only problem is white smoke at startup for some minutes and then is ok
